![]() | Home > Technical (L322) > 2004 Autobiography 4.4 V8 struggling to start when cold ? |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 569 ![]() ![]() ![]() |
Welcome to the Forum, hope this little issue doesn't put you off a great car.
Siclark Member Since: 05 Jun 2017 Location: Gloucestershire Posts: 40 ![]() ![]() ![]() |
So today parked at work at 8am, at 1pm turned ignition on but didn't try starting. At 5pm started it and it fired straight up no problem. Am I right in thinking that switching on the ignition at 1pm would've primed the fuel pump and brought the fuel pressure up to where it should be so when starting at 5pm there was sufficient fuel pressure to start as normal ? |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Have you tried to run it on petrol just before you turn it off ? prob might be tied in with the lpg side- or at least effecting the fuel pressure keeping pressure if you know what I mean!!
Yeah I tried running it on Petrol for the last 5 mins of my journey home last night but it still struggled to start this morning. |
oh well just a thought !! |
I've had some further issues today to add. Drove home from work fine, pulled up put it in Park and it stalled straight away. Approx 10 mins later needed to go back out and it really struggled to start, as soon as it fired up it coughed and spluttered and cut out. It did this 3 times before eventually running as it should.
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
I don't know enough about LPG but for me I would be trying to eliminate whether its an LPG issue or not? The only time I've ever had a similar issue with my (non-lpg) it was the fuel pump failing. Mine went quite suddenly, I was coasting up to some lights and then the engine spluttered and died. It fired several times but ran lumpy for a few seconds and died and then wouldn't restart again. I couldn't hear the pump prime after that when the ignition was turned on. There was no fault code thrown.
I've taken the plunge and bought a BMW X5 fuel pump, a fuel filter and a fuel pressure tester to see what's going on. I'll try and fit everything over the weekend and see what happens. |
Phils Member Since: 01 Aug 2016 Location: North west Posts: 71 ![]() ![]() ![]() |
I would suggest that this has all the symptoms of a failing sensor, in particular the crank sensor.
One thing I forgot to mention which makes me believe it's the fuel pump at fault is that before starting this morning, I pressed the Schrader valve in on the fuel rail and a tiny bit of fuel dribbled out and then nothing else so I'm guessing it lost all the fuel pressure overnight ?? |
That pretty much directs a fuel problem is at fault. But there have been a number of owners who found that it was a non return valve fault and by putting a replacement in they solved the problem. |
I'm led to believe the fuel filter has a pressure regulator built into it which if faulty can allow the fuel to seep back into the tank and therefore the pressure at the rail drops. |
Personally i thought it was in the pump, but i have never gone to the trouble of confirming that. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I have same model, with prinz lpg, of course run the car only on petrol while you get to the bottom of this. I had fuel pump issue, it would sometimes not start at all, and sometimes, it would, but not Rev, or drive. Bit of a nightmare to change, but there is a WIKI how that shows the procedure at top of this forum. If you are still in doubt over fuel pressure, you can buy a small device on eBay, to check it. Clip on a shredder valve. Be careful with spraying fuel from Schroeder valve, but that is a method. You could also change the fuel filter, as it's easy enough. One thing I was told, if you can thump the plastic tank sidebody, you might jar the pump into life, and if it's better the next start, it might help. The whole pump assembly is expensive, but you can buy a generic new Bosch pump on eBay for about £70. And fit it, being carful on disassembly. |
