Home > Maintenance & Mods (L322) > replacing standard wheel nut wrench with breaker bar
i've always had a breaker bar and small extension in the wheel well and never have or will use the supplied wheel nut wrench so, out that comes and the breaker bar goes in its place..
but i had to chop about 3cm's off the end to make it fit...
i also took out the triangular foam thingy that the lock nut goes in and replaced it with foam wrapped around the extension bar/socket and lock nut..
Post #441583 15th Jun 2017 2:12pm
ebajema
Good job Stan, I see you have been busy again !! I do hope you won't need the breaker bar ever though. Do you have the hydraulic sprinter jack in there somewhere as well ??
Instead of a breaker bar, I have a "cross wrench" in the back, they have worked well for me over the years. I am considering getting a long (60 cm) breaker bar as well anyway Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #441586 15th Jun 2017 2:22pm
sprinter jack is in the rear home made boot cubby .. Thumbs Up
Post #441589 15th Jun 2017 2:25pm
ebajema
Nice !!! MY 2010 5.0 SC Galway green and sand interior!!
Post #441592 15th Jun 2017 2:37pm
