Home > Technical (L322) > TDV8 Turbo Issues?
Page 2 of 3 <123>
rar110
Thanks Mikey, are they both equally good? ______________________________
Post #441196 11th Jun 2017 9:17am
rar110
Here's what I found from Mikey's part numbers
Right turbo:
old LR004526 new LR021045 BorgWarner 54399880111 OR 54399700111. BorgWarner TURBO MODEL: BV39-1872FFAAA426
Left turbo:
old LR004527 new LR021046
BorgWarner 54399880112 OR 54399700112
BorgWarner TURBO MODEL JV39-1872FFAAA426.18BVAXC ______________________________
Post #441200 11th Jun 2017 10:28am
GraemeS
Australia
n1cktdv8 wrote:
1. Is there anything owners can do to prevent turbo failure?
Ensuring that the 2nd, rear-most sump drain plug is also removed at each oil change as that plug drains a reservoir into which the turbo oil drains. The reservoir when not drained can fill with sludge over time which risks inhibiting oil flow from the turbos.
Post #441218 11th Jun 2017 12:39pm
n1cktdv8
Mikey wrote:
n1cktdv8 wrote:
Mikey - you are the resident turbo expert and I know I am likely asking questions that other 3.6 owners either have heard answers to before or are too afraid to ask. I also know it's a topic that's been done to death so I'll apologies up front Thumbs Up
2. Are there any early signs?
3. Is prevention better than cure (given any early signs)
4. Should we replace as a pair
Any feedback and help is appreciated. Mine is approaching 80k. Has had OTT levels of TLC and is a towcar for 1800kg caravan. It had a full transmission service at 70k and has oil and filter at every 5k.
Also...and this is the biggie....how much is it to replace the necessary should the worst happen.
thanks in advance,
From all 3.6 owners Bow down
1. Drive gently until fully warm. Not just until the coolant is up to temp, it takes much longer for the engine oil to warm up. Change the oil and filter every 10k MAX. Use only good quality oil and filters. After a drive, allow to cool before switching off, to prevent heatsoak within the bearings. Consider replacing the oil feed pipe at 80k miles...
2. Not really. They just go pop
3. Prevention is always better than the cure. A few quid spent on oil + filters is always going to be cheaper than a pair of turbos...
4. Always advisable. If ones turbo has gone pop, it's likely the other is not far behind it...
Price to repair is dependant on the repairing garage. A brand new OEM turbo is best part of £1000 + VAT each, and I wouldn't use anything else. Recon turbos are very hit and miss, as calibration can only be done at the BW factory (unless things have changed recently)
Cheers Sir. All nice easy answers which is appreciated on such a complex matter. Mine is in for service in next couple of weeks so I'll get the oil pipe feed replaced too.
Can anyone help with an LR part number for said oil pipe feed. Is this where I put the car details and a bit about myself ?........
Post #441226 11th Jun 2017 2:26pm
Mikey
LR006644 Thumbs Up
Post #441240 11th Jun 2017 3:58pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Any vehicles fitted with turbo(s) should be 'simmered' after a hard run.
IOW, let the engine idle for a couple of minutes (like after pulling off the motorway) to allow the turbos to cool. This will prevent oil carbonising in the turbo due to the extreme heat and no oil flow condition - which will eventually block oil flow to the turbo.
Post #441307 12th Jun 2017 11:07am
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
You're right Nick, Mikey is the turbo guru! I know Bow down Bow down Bow down 2014 vogue se
Post #441392 13th Jun 2017 8:29am
n1cktdv8
I did note your 'issue' and Mikey sorting it Thumbs Up
I think that's the reason for my question. My Rangey gets minimum daily use, then drags the tintent at a weekend, along with the family of 5 and all the associated junk. Now mine's hitting 80k I wanted to ensure I am doing everything possible to prevent any major issues. I'm booking it in for a service this week and getting Dan @ Duckworths to supply the oil feed pipe as per Mikey instruction. Is this where I put the car details and a bit about myself ?........
Post #441394 13th Jun 2017 8:59am
themule
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
Mikey, thanks for these tremendous turbo tips Very Happy
How much time would a specialist normally take to swap out either turbo or both or an 3.6? Cheers Andy
Post #441464 14th Jun 2017 12:11am
rar110
This is an interesting perspective on 3.6 turbo related motor failure.
http://engineengineering.co.uk/start/recon...368dt:979/ ______________________________
Post #441680 16th Jun 2017 12:33pm
themule
Interesting, but I wonder how much it costs?
Post #441693 16th Jun 2017 4:33pm
Mikey
Actual time taken, I can't remember
However, it's best part of a day's work to get bob turbos off the engine
Quite a bit of cleaning of intake/boost pipes to remove oil from the system
Always takes a bit longer to go back together
20-24 hours wouldn't be unreasonable, despite what the book time says...
Post #441724 16th Jun 2017 9:28pm
Nespouls
France 2007 Range Rover Vogue TDV8 Adriatic Blue
Could I ask for turbo advice, please - - after barely two years of owning my TDV8 I am suffering early onset FullFat anxiety.
She is a 2007 model about to clock up 200,000Km, but has been regularly serviced by the local LR garage. There are service entries every 20,000Km or so. Having read this forum avidly, I realise that this is far too infrequent.
I had an EGR failure in Spain and was able quite easily to drive her back to France by keeping the revs above 2,000. Both EGRs were replaced by my local LR garage and very soon after (300Km) the top hose blew off the thermostat block. I have just replaced the block (on which each hose junction was littered with pink crystals which was totally visible to the garage, but they said/did nothing) and am alarmed by the state of the air inlet tubes, by the throttle. One side is very oily and the other, the side on which the EGR failed, is very sooty.
Also, when draining the engine oil the second, vertical, drain plug very little oil came out, barely enough to cover the bottom of the collection bowl - - are the turbo oil return pipes blocked . . . ?
So, my question: how worried should I be about imminent turbo failure?
Cheers,
Stuart Stuart
L322 2007 TDV8 Vogue
Post #442942 28th Jun 2017 1:13pm
Mikey
Wouldn't be worried at all Thumbs Up
The excess soot is perfectly normal with a faulty EGR valve
The rear drain does not hold much oil at all, around 300ml from memory Confused
Post #442978 28th Jun 2017 8:24pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Second what Mikey says, I changed my EGR valves and had lots of sutt to clean out of the pipes and throttle body. The second sump plug only holds a small amount and is to get rid of any sludge. Just clocked 134k on mine, I change oil and filter at least every 8K to keep it all clean. Thumbs Up
Post #442983 28th Jun 2017 9:05pm
Page 2 of 3 <123>
