Hi all,
Posting on behalf of my Grandad!
He has a 2002 Range Rover, which he hasn't had much luck with.
The problem started with the key not turning in the barrel, since then the steering column has been replaced, thinking it may be the ECU housed there. He has also replaced the ignition barrel for the key. After this was done I have found on the Lynx Diagnostic tool that the engine immobiliser code is showing..
When you stick the key in and try to start everything is working, it just wont turnover.. Which makes me think it is more electrical than mechanical.
So I suppose our question is, after the installation of a new steering column, does this need to be programmed in with T4 or similar?
Any help would be greatly appreciated
