![]() | Home > Technical (L322) > Gearbox...is it gone? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
http://www.valvebodyuk.co.uk/ will supply Sonnax fitted valve bodies on an exchange basis.
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
You might find a bit of info in here, I was having a read of this thread a while back.
This might be the place.
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 ![]() ![]() ![]() |
Thanks Hamlet, |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
@Cooper1275 - no - I jus had the gearbox /torque converter rebuilt and they used higher spec parts. Main dealer offered to do it for £5k (replacement box) but the rebuild was just as good and once I got it back, I realised how 'sloppy' the gear change had got as the new one was seamless with the change, very smooth. I guess it gradually goes over the years but you don't realise as it is such a steady decline. The guys who did mine said that basically the oil burns up . They put a higher spec oil in aswell (£120 worth) and gave a 2yr warranty I think but said it would not fail. Steve
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
as you mention that the oil burnt up, is there any chance to fit a better oil cooler?
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Hamlet has posted the guy that i had heard about 😀 2015 4.4 AB
Well i spoke to Paul in http://www.wexfordtransmission.ie/ and out of everyone i spoke to he was the best. |
MatsonTAS Member Since: 13 Feb 2016 Location: GENT Posts: 31 ![]() ![]() ![]() |
Yeah, I have been following this topic with great interest. I had a leaky transmission pan gasket and brought it to at least 4 places around Dublin. All quoting different amounts for a oil an filter/pan change. I finally went with Cassidy Motors in Dublin 12 as they had the best reputation and chat. Filter and oil changed but the man insisted a recon is due in the next year or so. Workmanship was great as I waited on the car. They have all the stuff and spoke about recon incl new torque converter and so called zip-kit for the solenoids in the valve body as well as hd clutches etc. I believe he quoted around 2100-2600E. They seemed sufficiently knowledgeable but havent done the recon as the box seems fine now. Just slips slightly on the 3-4 shift... Feels like she is in between two gears, holds the rpm as she accelerates and then finally goes to 4th.
looks like there is finally a solution for the 5le40 to last longer than oem.
Give Paul in http://www.wexfordtransmission.ie/ a call and see what he says. I did try Cassidys but Paul seemed better. |
nebc100 Member Since: 14 May 2017 Location: Altlinster Posts: 76 ![]() ![]() ![]() |
Is there any update on this?
Just got mine back today |
Got mine back a week ago.
