This applied to the earlier cars. Don't know if still so for the later ones:
"Listening to Radio with the ignition
switched off
With the ignition switched off, (ignition key
turned to position 0 or removed), the radio
functions remain available for approximately 20
minutes.
When the ignition is switched off, the unit is also
switched off.
To switch the unit on again, press the 'On/off,
volume rotary control' (17) or the 'Audio' button
(5).
NOTE: The unit cannot be operated via the
multifunctional steering wheel when the ignition
is switched off.
To protect the battery, you should always switch
off the radio when leaving the car." John
GAP iiD BT-Sold
