Home > In Car Electronics (L322) > Removing fixed phone kit from upper cubby
JPJ64
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Has anybody removed the standard phone connection kit from the upper cubby and replaced this with a simple tray for their mobile or ipod? If so, any pointers on where to get a tray from?
Ideally I'd like to add a USB port in here too to connect my iPod to both power and aux, has anyone managed to do this? (I have the rear Aux in and lighter socket so I reckon it shouldn't be too difficult?)
Post #442417 23rd Jun 2017 12:40pm
Shaun_
Hi
Yes - I've done this. There is and OEM tray insert available but it's very expensive - especially for something that will rarely be visible I made a simple insert from some stiff card and thin black neoprene sheet bought on fleabay. At the same time I bought a connector cable which I've simply plugged into the rear aux port and then run through the rear 'vents' below the panel that holds the aux port and 12v sockets and through to the cubby via a small hole drilled into the rear.
It's all quite neat and unobtrusive, and as you say means you can keep an iPod or phone in the cubby providing both sound and power. 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #442425 23rd Jun 2017 1:43pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Re: Removing fixed phone kit from upper cubby
Unnecessary quote removed
This si the OEM upper tray £19,95 on the bay
https://www.ebay.co.uk/p/Land-Rover-FJB000120PVA/1213803028
Post #442428 23rd Jun 2017 1:50pm
JPJ64
Thanks Berkshirelad
Post #442503 24th Jun 2017 1:12am
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Currently sold out ! The power of this forum .
Post #442517 24th Jun 2017 8:12am
JPJ64
Well I knew it was too good to be true!
I bought that upper cubby tray from eBay and guess what, yep it was the wrong one 😠
Looking at the current arrangement, if I could just remove the handset cradle, then the rest of the upper tray would be perfect for what I have in mind. Has anybody managed to separate the phone cradle from the upper tray?
Post #443688 5th Jul 2017 10:14pm
JPJ64
So its out (photos to follow). Quite easy really, undo the torx screws in the underside of the divider between the upper and lower cubby, unscrew the phone cradle and disconnect the wiring. I'm left with a hole between the upper and lower cubby where the phone release button was, but I'll tackle that in phase 2 when the Alpine goes in.
Post #445585 24th Jul 2017 4:16pm
