Home > In Car Electronics (L322) > Digital TV Upgrade
Page 10 of 18 <123 ... 91011 ... 161718>
M44K TS
Wiggs, you don't do the tv upgrade for a 2003 model do you? 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #44257 2nd Jan 2011 8:37pm
wiggs
No sorry only the later touch screen ones
Post #44396 3rd Jan 2011 8:19pm
wiggs
Andpopse wrote:
Do you need to use the auto soft button every time ? I get a differing number of channels depending on location/reception area.
if you stay in the same area all the time , then no . You can store any station you want by holding down one of the 1-9 buttons for a few seconds till it changes colour .
If your driving about then you will get different amounts of stations , depending on were you are .I always just press the auto button , as that finds all the stations it can in one go . You can manually search through if you want , but i like to be able to see at a glance whats available .
Post #44532 4th Jan 2011 6:11pm
Andpopse
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Thanks Wiggs.
I am also interested in your upgraded Bluetooth unit. Does it work with iPhone 3 (and 4 soon). And how much?
Thanks
Andy
Post #44613 4th Jan 2011 10:34pm
wiggs
Yes works with iPhone 3 and 4 Thumbs Up
Pm'd you
Post #44617 4th Jan 2011 11:13pm
duka
2010 Range Rover Autobiography 4.4 V8 Alaska White
Hi new on here & just sold my 110 defender acquired a 2006 RR with rear entertainment.
Wiggs, do you have any more digital tuners & do they come with an idiots guide to installing? my vehicle has the touch screen on the dash.
Thanks
Steve
Post #45582 11th Jan 2011 5:26pm
duka
Thanks
Steve
Post #45583 11th Jan 2011 5:28pm
wiggs
Hi
I do have one ..yes
There is some posts on here regarding fitting it . I only have a disco 3 so i cant do you a "how to guide im afraid "
Im sure someone who has done it will be able to give you some pointers .
Post #45585 11th Jan 2011 5:31pm
Chemgopete
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Hi
Fitted a digital tuner from wiggs a few months ago. Removed the left hand (looking into the boot) side panel put 2 strips of 1 inch wide double sided tape on the top face of the new tuner and stuck it to the face of the old tuner with the tops level. There's just enough room for both as the new tuner is slightly thinner. It's easy now to change the plugs over as they are the same colour codes. Simple to do in about 5 minutes.
Bluetooth module works great to (thanks to WIGGS)
2006 face lift touch screen FFRR.
Post #45596 11th Jan 2011 6:57pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Hi Duka, if you have the LR rear entertainment system, then you can't just stick the new unit in as there is no room, you need to remove the old analogue one and put the new one in its place (but you only use 2 of the original 4 bolts to hold it). If fitted one of Adrians last year and also have the rear entertainment, I described how to do it on page 5 of this thread if that's any use to you. It took me around 2hrs originally, but I can now remove all the kit and replace it again in around 30-40mins max.
Cheers Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #46149 15th Jan 2011 11:28am
paultuk
Hi Wiggs,
I'm interested in the Bluetooth module upgrade. Do you need my old module or is your service for a complete replacement??
Also do you know if there is a way of changing the Analog Radio module for a DAB one???
I have a Facelift 2006 TD6.
Thanks for your time.
Kind Regards
Paul
Post #46290 16th Jan 2011 9:44pm
wiggs
Hi
I'm in the middle of testing a dab radio , but have a issue with the module .. Will post back when I get another module
Have pm'd you regarding the Bluetooth
Post #46296 16th Jan 2011 10:02pm
duka
Cheers
Many thanks Steve, hope to get close to it this weekend - I can take pre-post pictures if anyone is interested?
Post #46368 17th Jan 2011 2:36pm
paultuk
Just want to say a big thank you to Wiggs/Adrian for his fast Bluetooth module upgrade!!
Excellent service!
Lots of egg on face at my Local LR Dealer when i told them i had a replacement module which works perfectly with my iPhone 4!!!
Recommend anyone having iPhone 3GS / 4 Pairing / Phonebook issues get in touch with this guy!!
Happy Customer here! Very Happy
Paul
Post #47615 26th Jan 2011 12:21pm
Jsb
Wigs: any update on the DAB upgrade stuff you mentioned? Is this likely possible with older front screens?
Post #47635 26th Jan 2011 2:22pm
