![]() | Home > My Range Rover > My new 2012MY Vogue 4.4 TDV8 |
| FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 222
Finally picked up my new (to me) 2012MY Vogue 4.4 TDV8. After 5 months of searching the German market and 7 test drives I finally settled on this, the sixth car I tested. Of all the ones I tested this felt the nicest and its condition was just about the best of the bunch. So it was finally out with the old...
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2781
Perhaps the same as Australia where ACC was not offered as an option. |
It is mentioned in the 2012 German brochure. I saw pictures of an Autobiography online that had it fitted and I heard it was standard to the Autobiography. Haven't seen it on any Vogues, though. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
| 362bkr Member Since: 15 Oct 2014 Location: Devon Posts: 680
Looks great , once you get the steering wheel moved to the correct side it will be perfect |
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119
Congrats Frank. I'm in the same position as you and seriously considering going from a 3.6 Vogue to a 4.4 tdv8, although might consider a petrol v8. It took me 6 mths to find my 3.6. I'm expecting it will take the same for a 4.4 if I go that way. ______________________________
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
Unnecessary quote removed
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Looks great! Well done. Cheers, Greg
You notice the difference in power. It accelerates quicker and the gear changes are smoother. The ride is quiet although I think the motor is slightly noisier than the 3.6 but then it is more powerful. Those are the main differences I've noticed so far but I've only driven it twice. Spec-wise there are many differences to the 3.6 (mine was an '08 model). Most of the changes came with the '11 model and are listed in the press release for that year. I like the updated interior and digital binnacle. Keyless start is new to me and I'm eager to see how reliable it is over time. Mine has the vision pack so it has the blind-spot warning in the wing mirrors which is good but I wouldn't trust it implicitly so I still do the shoulder glance before overtaking. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black 2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Don't know why I had an 'Unnecessary quote removed'. I was clearly refering to a much earlier post in the thread rather than the immediate post above. |
ACC can easily be retrofitted if you have an IIDTool to modify the CCF parameters and to set the radar unit to calibration mode. The radar unit and bracket, link harness and the steering wheel switches need to be procured. |
| Doc Member Since: 27 Jun 2017 Location: Kristianstad Posts: 7
Very nice! I do the same job right now. Looking for this beauty! My first one |
| FrankN Member Since: 11 Feb 2017 Location: Vellmar, near Kassel, middle Germany Posts: 101
Hallo Frank,
Only these two:
| All times are GMT |
