Home > Technical (L322) > Very strange airbag fault
Sandyt
Evening all right so I have an airbag fault that appeared last week then I had a load of other faults so rolled back the CCF to sort that lot and just for good luck replaced the battery and was left with airbag fault interestingly when I went out and looked in the morning no fault so I have tracked it for a week and if the outside temp as showing on the dash is less than 22 degrees c no fault but above the fault is there and no amount of 11d tool clearing shifts it
Anyone any idea what is going all ??
Post #442689 25th Jun 2017 9:16pm
There are a couple of other threads concerning the recent warm weather playing havoc with electrics, it could be down to this.
May well be worth check/clean/fettle all of the connections. Remember proper battery disconnection procedure and time to die requirements for the airbag system before any disconnections! .
Post #442701 25th Jun 2017 11:16pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
"Remember proper battery disconnection procedure"
i would like to know what the procedure is
i am new to this modern gear and have wanted to disconnect my battery but darn't
thanks
Post #442706 26th Jun 2017 2:37am
It is all in the wiki knares
http://www.fullfatrr.com/wiki/
http://www.fullfatrr.com/forum/post67804.html#67804
You will need to get it unlocked first to get at the bonnet release Thumbs Up .
Post #442739 26th Jun 2017 12:13pm
knares
thanks
i found it and now i know where wiki is
great
my son just put the key in the door, just like i did, but it just opened for him
Post #442750 26th Jun 2017 2:20pm
Sandyt
Got to the bottom of it it is the airbag that has failed so will replace
Post #446642 4th Aug 2017 6:12pm
Sandyt
New airbag snip at 650 quid plus the fitting fault gone so now on to the next Thumbs Up
Post #447513 11th Aug 2017 5:20pm
