Home > Maintenance & Mods (L322) > TDV8 Diff and Trans oil
Page 1 of 3 123>
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Hi folks,
I am looking to change the oils for Diff and Auto Transmission and have few questions:
a) What oil is recommended for Front/Rear Diffs (and Transfer box if there is one) Please can someone help with the capacity of each?
b) What oil is recommended for Auto Transmission? I have checked the WIKI but they seem to refer to TDV6. Is it easy to change? Do I have to replace the filter too? or can I do a drain and refill. Or shall I get it done professionally.
Please advise Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #443075 29th Jun 2017 9:28pm
scotcruz
ok so looked at the owners manual which tells you the capacities. Did a further digging and now understand it's 75w 90. I will be using a fully synthetic oil so that's fine.
on my travels I also seen some threads suggesting the Shell TF0753 recommended for the transfer box is also 75w 90 spec. is this true? Thinking of getting a 5 litre Miller's 75w 90 bottle and change the oil on all three..
Question:
a) do I have a locking diff or unlocking? how do I find out?
b) Topix says mine is Euro 4. How do I know if mine has a DPF? Current:
Past:
Post #443084 29th Jun 2017 10:52pm
The transfer box is a specific LR oil.
You can only get it from LR. It's different from the diffs There is nothing that can't be fixed with a hammer😜😜
Post #443089 30th Jun 2017 7:09am
scotcruz
yeah I read on one of the other threads showing an LR bottle reading Special Transfer Oil but the owner manual says it's Shell TF 0753 which upon further investigation is 75w 90.
Has anyone else changed the oils recently?
Can someone also help with my diff lock and Dpf questions? (Didn't want to start a new thread) Current:
Past:
Post #443091 30th Jun 2017 8:07am
stu
I'm waiting for the rain to stop to get on with this and servicing, I bought the diff fluid "Castrol" from Opie oils and the transfer fluid from Dan, genuine L/R stuff Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443116 30th Jun 2017 10:36am
scotcruz
Stu was it Castrol 75w90? also how much was the LR transfer oil? Current:
Past:
Post #443117 30th Jun 2017 10:51am
stu
the L/R trans oil is £22 per litre from Dan
the diff oil was £24 (that was for 2 bottles) so £12 per litre with your (FULLCHAT) discount code.. Thumbs Up
I bought the SAF-XO (first bottle)
http://www.opieoils.co.uk/c-673-75w-90-gear-oils.aspx Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443123 30th Jun 2017 11:26am
stu
nothing to do with diffs, but just looking at your handbook picture, I thought so, the fuel tank on the 4.4TDV8 is smaller than the 3.6 or TD6 for that matter.
Any reason that anyone knows of? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443125 30th Jun 2017 11:31am
more efficient so needs less fuel but still gets the same range, hadn't noticed myself however it did seem a bit cheaper to fill up..... There is nothing that can't be fixed with a hammer😜😜
Post #443148 30th Jun 2017 5:35pm
stu
Thought it would be something like that! Could do with extra couple of gallons when the tin tent is on the back... Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443157 30th Jun 2017 7:03pm
scotcruz
any idea on questions a) and b) in the second post above folks? Current:
Past:
Post #443164 30th Jun 2017 7:53pm
stu
You will have a locking centre diff but as to an active rear diff there will be wires and a plug on the top.
My advice is to send an email to JLR customer services with your chassis number and ask for a copy of the build sheet for your car.
This will give you the full spec of your cat Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443165 30th Jun 2017 8:00pm
scotcruz
is that not the same buildsheet you get from Topix? Current:
Past:
Post #443170 30th Jun 2017 8:21pm
stu
No idea as I've never used it! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443172 30th Jun 2017 8:44pm
nino_nino
this will give you buildsheet :
http://www.vindecoderz.com/
Post #443176 30th Jun 2017 9:05pm
Page 1 of 3 123>
