![]() | Home > Technical (L322) > Another reduced performance! |
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927
Stupid ipad how many times has it posted code picture..
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8091
You could have just edited the first post rather than making the thread even longer |
Suitably edited Alistair... |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3864
Look at the 4 ports on the manifold.
Sorry to be blonde which manifold? Current: TDV8 (3.6) RRS HSE
The air intake manifold.
Thanks for that! The pictures hadn't loaded on my iPad when I looked before all there now.
Whilst you are under the front of the car, you might want to check the air change-over valve to see if it is modified.
Will do thanks...unfortunately my car is out of warranty so it's all down to me.. |
| Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369
We had a problem with the inlet manifold on our 4.4 TDV8 last year whilst in France. It showed itself as a 'Reduced performance' issue. It would initially reset itself if I turned the engine off and on but eventually stayed on permanently. The manifold had actually split and had to be replaced by a dealer in France. |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765
just been out and checked mine for POM, it seems that i have the non nut version of the air changeover valve so thats good. Now in terms of the 4 little rubbers.
NMJ,
Definitely smooth, no ridges.
