![]() | Home > Maintenance & Mods (L322) > DPF Full Warning |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786
basically yes.....
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
Not sure that The 3.6 tdV8 suffers the same turbo drain fault as the 4.4 tdV8. G reg 2.5VM Vogue Portofino red 1991- 1999
| scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391
cheers.. I'm surprised there was mention of this anywhere.. mine is out of warranty anyway so guess I need to keep an eye.
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927
The 3.6 is set up differently to the 4.4 so I wouldn't unduly worry about this! Current: TDV8 (3.6) RRS HSE
Cheers Stu.. I take it 3.6 doesn't a twin turbo? Current:
http://www.fullfatrr.com/forum/post319625.html
Sorry missed that scotcruz had a 3.6.
panic over lol.. Current:
Scotcruz Would have a quick look at the top turbo hoses (take them off takes 5 mins) as a starter 4 ten just to check they aren't starting to split and give the MAF a clean. Black smoke is generally overfuelling so that would be where I would start. If everything checks out then i wouldnt worry too much. There is nothing that can't be fixed with a hammer😜😜
