![]() | Home > Maintenance & Mods (L322) > gen LR ipod ACM fitting into an my05 questions |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
hi guys i believe im right in saying the above does fit and work ?
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
You're right Mark. That's the correct unit. |
supurb ive ordered the kit , will pick it up in the week so thaught i would make a start on the job thank u |
Exactly, as happy says.
now that i know how too do it start to finish with fitting probably about hour and half ish its not a big nightmare that you imagine it to be |
LR004806 @ about £300+ ish guy salmon LR in coventry 0844 470 7159 have 20 odd in stock |
kil2508 Member Since: 05 Sep 2010 Location: Wales Posts: 20 ![]() ![]() ![]() |
Thank you! |
all fitted and fitted perfect so lets put this to bed that the kit WILL fit early facelift vehicles 05 -06 onto no6 Range Rover
There was a post on RR.net the other day where someone stated that aux-in (aside from the ipod) didn't work on pre07 vehicles. Was/is this a prob on your RR? |
ben2012 Member Since: 10 Jan 2011 Location: West Yorkshire Posts: 54 ![]() ![]() |
Hi just wondering how the iPod integrates into the screen? Does it display any track info etc? Also where do u plug the iPod into?
@Steve, IIRC the AUX works with the red and white phono to 3.5mm mini jack with no issue. ditto the USB. I'll re-check when I get mine back at the end of the week.
Chemgopete Member Since: 16 Jul 2010 Location: Birmingham Posts: 9 ![]() ![]() ![]() |
Can you play video from the iphone if the ACM is fitted? |
As I understand it. No. The only way I heard of is via the yellow, White and red Phonos with the official cable- and then only on the rear screens. AFAIK there is no way of getting iPod videos on the front screen.
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1118 ![]() ![]() |
Am I reading this right, if I want to use my ipod in my 55 facelift then it will cost £300 for the parts and an hour and a half. letters not necessarily in the right order |
