![]() | Home > Maintenance & Mods (L322) > Place your bets |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
1. If you can hear air you have a leak, it will either be a leaking airbag or the feed pipe will have chaffed through. There is a thread on it on here. Can be fixed with a straight connector.
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
Thanks for the Info Unfortunately I'm working for 12 hr shifts for the next week so won't get chance to have a good poke around guess i'll have to swallow a bill and hope it's nothing major |
Well got the chance to dive under the hood tonight as it's a nice evening and it took me ten minute to whip off the intercooler hose give a wash and locate the problem,as you can see from the photo it split underneath in front of the throttle body never would of found it had it not been for NorthernMonkeyJones thanks you where a real help
the tape from Halfords will fix it temporarily while you wait for a hose to arrive |
Had a roll of gorilla tape in the garage just need to pop down and get a replacement L322 2008 vogue
That'll do it too. |
Well it's been into the main Dealers for two days now so i've had the pleasure of driving around in new disco sport and for princely sum of £110 they have come back with diagnoses
Give Dan a shout on the compressor, he can get oem parts as well as LR. Worth a shot and will no doubt be cheaper than the dealer. There is nothing that can't be fixed with a hammer😜😜
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2694 ![]() ![]() ![]() |
Got a compressor from dan last year, whilst pricey, no where near that amount ! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Odd that later model reservoirs are going rusty... .
I should be getting the car back today and i'm not saying I don't trust the techs but i'm going to check the relay and fuses before I order as I've had them diagnose a dead fan before now and it turned out to be a switch L322 2008 vogue
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
I believe the early l322 had an alloy tank then JLR started using steel resiviors which are common for failing |
Bigald Member Since: 16 Jul 2017 Location: West Yorkshire Posts: 41 ![]() ![]() |
Thanks to northernmonkeyjones just had car in for service they plug it in and said looks like you need new turbos asked if they checked hoses yes all good so when I got home hoses off right hand side 1 split gorilla tape and no more engine failure and limp home mode once again thank you everybody
