![]() | Home > Technical (L322) > 4.4 TDV8 MAP sensor |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
I doubt yours will be dirtier or more blocked up than either mine or NMJ's and neither of us have reported any restricted performance alarms, so I doubt it. G reg 2.5VM Vogue Portofino red 1991- 1999
Nino Nino,
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
I need to re arrange some of the pipework in this area.... the feed coming off the rad hose which goes to the left hand of the green circles, is the wrong side of the other hose, which is then chaffing on the engine cover. Good to know this push fit connection can be taken off cos I can then put it back in the right place so it sits in the channel on the foam padding |
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927
Battery disconnection it is first then. How do I get the lager to Bosnia if your right? Will Hekwap do?... |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
Hekwap will do just fine stu |
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2774
Mine too! |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
done mine today and it was clogged up like all yours..
I found this link posted by rar110 helpful.
thank you mike...i should really have read the thread again |
so would a clogged up sensor really make that much of a difference in the performance of this engine...anyone found the engine more responsive after a clean... ... - .- -.
I cleaned mine at the weekend then had the 80mph cough software update done on Monday so I can't really say which had the most effect, but it was certainly running well yesterday.
| mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 913
I don't think it would make much difference Stan. As it's a pressure sensor, providing it's not sealed from the pressure in the inlet manifold, then having soot all over it would only have a minimal effect. |
looking forward to your report mike #1 .. |
O she does, |
