Home > Technical (L322) > i hope this is not correct
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
Post #443590 5th Jul 2017 9:36am
Weegie
Did you reset it and then check the figures right away or very soon after? If so that would explain it. The figure given is an averaging one not a direct one.
If you reset it whilst running at about 50/80 kph you will get a very different figure. Thumbs Up As it is an averaging figure it doesn't reflect real time. John
GAP iiD BT-Sold
Post #443594 5th Jul 2017 9:46am
Alfasprint88
New Zealand 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Supercharged??????
Post #443597 5th Jul 2017 10:10am
ebajema
When idling the computer doesn't have KM's to use for the calculations so the calculations are a bit off. When driving the calculation is based on distance driven and fuel injected (theoretical, based on the opening time of each injector and the theorectical fuel amount being injected). This is according to a friend of mine who used to work for JLR. MY 2010 5.0 SC Galway green and sand interior!!
Post #443599 5th Jul 2017 10:40am
knares
thanks for your reply's guy's, thought it odd
Post #443674 5th Jul 2017 8:12pm
