Home > In Car Electronics (L322) > Touch screen stereo nightmare
burnout
England 2004 Range Rover Vogue Td6 Zambezi Silver
Help needed guys . I have a 2003 l322 td6 running the amp in the boot and the sat nav . I'm trying to fit an xtrons touch screen stereo . I know I have to get the long cable which goes to the boot and plug into the amp . I have bought 2 different types so far and only one works but you can only here the music very quietly and it killed the battery in half an hour . Was meant to be a play system but something is wrong. Has anyone managed to upgrade and come across this problem. And cured it . Any advice and help would be most welcome
Post #437538 8th May 2017 4:39pm
Johnsd1v8
United Kingdom 2004 Range Rover Autobiography Td6 Zambezi Silver
I think all the units in the back talk to each other mate via fiber optic if you have the MOST TOUTCH SCREEN system and if the loop is broken nothing will operater correctly
Post #443751 6th Jul 2017 7:10pm
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I just had one fitted by John Kleis in Reading, Fibre optic is a bit of a misnomer- it isn't in every vehicle.
They didn't feed the wires they cut and soldered the existing running wire and fitted a small amp to run the sub in the boot
Post #443800 7th Jul 2017 12:23pm
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
@ ohuntsman: Can you tell us which replacement headunit you had installed please?
Post #443801 7th Jul 2017 12:29pm
ohuntsman has a 2002 FF which does NOT have the MOST fibre optic wiring.....
edited mistake which was due to heat stroke.... ... - .- -.
Post #443802 7th Jul 2017 12:35pm
Rolling with laughter You should probably have capitalised NOT rather than DOES Whistle
Post #443803 7th Jul 2017 12:46pm
Embarassed Wink ... - .- -.
Post #443807 7th Jul 2017 12:56pm
ohuntsman
I got the Pioneer SPH-DA120 - Stan I figured that the 2003 would be similar to the 2002?
Post #443814 7th Jul 2017 2:56pm
i was replying to gyre8 who has a 2006 and hence the MOST system.. ... - .- -.
Post #443817 7th Jul 2017 3:39pm
Danwilderspin
You will have ibus and the amp need to be switched on by ibus as it is.
I had this same bs! The dsp can be recoded if you find a dealer that will do it so it acts as a standard amp just powering on and off by the switch live.
If you can find someone great - if not I went down plan b and bought the none dsp ampnand wored it in now it's happy days! The Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #443969 8th Jul 2017 10:19pm
