Home > Maintenance & Mods (L322) > 2006 Range Rove lost cell phone in Rear Seat Return Air Duct
2006Rangie
Canada 2006 Range Rover HSE 4.4 V8 Giverny Green
Was driving today and braked and swerved. Rear passenger had cell phone on seat; it slid off, bounced on floor and slid down the return air duct under the driver's seat. The passenger side has a safety grill over the duct opening but I never noticed that the grill was missing on the driver's side.
Anyway, we called the phone and could hear it vibrating in the duct. I rented a bore scope and found the phone using the video camera but it is buried about 10 inches down the duct and inaccessible. Tried a flexible clamshell retrieval tool but no luck. Tried sending a section of garden hose attached to a vacuum cleaner up the duct hoping to grab the phone; no joy.
The duct is approximately rectangular 2 inches high by about 8 inches wide. It has a vertical drop of about 2 inches then leads forward horizontally to who know where and I can't get my hand in more than a few inches.
Any suggestions? Can I remove the duct without removing the driver's seat? Is there a diagram of the duct showing how to remove it?
Appreciate any ideas,
Post #443870 8th Jul 2017 3:50am
You could try driving up a very steep slope and then call the phone to see if it vibrates and slides back to the opening. Thumbs Up Very Happy
This is the duct layout. The duct is actually a supply duct to the rear.
Post #443929 8th Jul 2017 4:18pm
Metal coat hanger with hook on the end, using 'scope to guide you, drag it back towards opening, then get another hook on it and pull it up and out? Or send similar coat hanger thing with something very soft and sticky on the end and do the same? Or a magnet ? (depends on phone - I guess very few are made of iron!)
Looking at the diagram looks like you could possibly pull the back end of the vent off, but then the phone would likely fall into the under carpet area, and you would have a hell of a job getting it all back together.
Fishing seems the best solution ?
Shame it is not a mouse, these seem easier to retrieve Laughing .
Post #443935 8th Jul 2017 4:56pm
GGDR
is there enough metal in a phone for a magnet to bet it?
Otherwise I like your suction idea. But maybe you need to fashion a wide flat hose something-or-other, gaffer tape it to your vacuum hose and try to feed it it. If you were even able to make rubbery end it would help suck and then hold it on the end of the hose using the suction.
Good luck!
. Cheers, Greg
Post #443938 8th Jul 2017 5:14pm
try a battery reset Mr. Green
seriously though, it does sound like a seat out and strip down.... ... - .- -.
Post #443939 8th Jul 2017 5:20pm
nino_nino
i like Joe90 idea, coathanger and when you drag it closer use another coat hanger with some glue for mouse catching . nasty and very sticky stuff.
good luck Thumbs Up
Post #443951 8th Jul 2017 6:08pm
mjdronfield
Blu tac... coat hanger..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #443952 8th Jul 2017 6:24pm
Coat hanger with a hook on it. There is nothing that can't be fixed with a hammer😜😜
Post #444001 9th Jul 2017 8:38am
nino_nino
Post #444010 9th Jul 2017 11:00am
Rolling with laughter @ stan .
Post #444011 9th Jul 2017 11:02am
2006Rangie
Unnecessary quote removed
Thanks for the input "Nice Day". I see that it is a supply duct rather than a return and the diagram is useful for understanding the general arrangement.
I wonder if I can find a 'very steep slope' in Melbourne, Florida - terrain here is pretty flat! That would be a fun exercise and a non-invasive way to recover the phone. Must be a sand dune or ditch somewhere.
Post #444052 9th Jul 2017 5:11pm
2006Rangie
Thanks Joe. Good ideas. Have tried a hook, no joy so far. Still working on it but a new phone might be necessary as an interim.
Post #444053 9th Jul 2017 5:17pm
