Home > Technical (L322) > Reduced Engine performance
forever
Message popped up for the second time in about 6 months after a long run both time I have plugged in the gap tool but nothing revelent seems to be logged at least for the engine, transmission or suspension there are other messages about immobiliser and lost bus connections or low voltage Smile
Amy clues it's a 2006 4.2 S/C...
Mark
Post #443941 8th Jul 2017 5:38pm
forever
Below is the output of the gap tool
VIN SALLM
Model L322 - Range Rover 2006
Vehicle scanned on 8 Jul 2017 17:18:15
IIDControl 2.9.4.5 Android - IIDTool BT V3.0 B2134
AAM-Audio Amplifier
• B1A06-13 (2F) Speaker 6 circuit - General electrical failure - circuit open
( at 137130 km )
• B1A05-13 (2F) Speaker 5 circuit - General electrical failure - circuit open
( at 137130 km )
ACM-Audio System
• U2003-86 (2Cool Fibre optic communication bus - Bus signal/message failure - signal is invalid
( at 138398 km )
HVAC-Heat / Cool
• 0x30 Air quality sensor line fault
LCM-Light Control
• 0x5B Washer fluid level fault
TCCM-Transfer Case
• P0562-00 (2Cool System voltage low
( at 0 km )
TMC-Traffic Message
• B1A56-18 (2F) Antenna circuit - General electrical failure - circuit current below threshold
TVM-Television
• B1D55-11 (2Cool Unknown
( at 16777215 km )
• B1D55-13 (2F) Unknown
( at 16777215 km )
• B1D57-12 (2F) Unknown
( at 16777215 km )
• B1D57-13 (2A) Unknown
( at 16777215 km )
VIM-Immobilizer
• B1B01-87 (2C) Key transponder - Bus signal/message failure - missing a message
( at 137130 km )
• U0155-87 (2Cool Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
( at 137441 km )
Post #443942 8th Jul 2017 5:39pm
Dolphinboy
My initial thoughts are duff battery.
Post #443943 8th Jul 2017 5:42pm
forever
Interesting thanks will stick it on the cteck to see what it says tbf most of the journeys are short....
Post #443946 8th Jul 2017 5:47pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Have you checked your Aux Coolant Pump is wired the correct way round?
http://www.fullfatrr.com/forum/topic26796.html 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #443981 8th Jul 2017 11:30pm
forever
Maybe a fault codes should be logged, perhaps I have the gap tool not setup right, but you would think if it triggers a warning on the dash then it should also log a code
Post #443985 8th Jul 2017 11:52pm
stu
If you plug in your IID, go to faults, open the advanced menu, make sure that PENDING, CONFIRMED AND MIL REQUESTED are ticked, click on save and take it from there. You should get engine faults etc from that.
Let us know how you get on.. Thumbs Up Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #444043 9th Jul 2017 4:30pm
forever
Sorry for the late 'reply, charged up the battery w as only on 3 on ctek, not seen the message since, did have a random low coolant message come up but checking under bonnet it's on the Mac line, got to love land rover electrics Smile
Post #446140 29th Jul 2017 7:01pm
