![]() | Home > Maintenance & Mods (L322) > Transmission sump |
| unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 130
It isn't necessary to fiddle with engine mounts and drop exhaust on FFRRs. All reasonably accessible from below. The Discos and RRSs are a different matter. |
| birchyman71 Member Since: 18 Feb 2013 Location: stockton on tees Posts: 147
If it's leaking from the sump / gearbox joint there's s good chance they have over tightened the bolts or not tightened them in the correct sequence , unfortunately you'll probably need to drain it to correctly seat it and tighten it , |
Just from memory , someone will soon correct me the torque is about 12Nm for the bolts and the sequence is start in the centre and rotate through alternate sides ( like a cylinder head) |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1045
Diagram on the right is the 6HP26
| All times are GMT |
