Home > General > What should I do???
nebc100
Luxembourg 2003 Range Rover SE Td6 Monte Carlo Blue
What should I do???
Hello All,
I cannot decide what to do!!
I currently have a D2 TD5 (manual) that I have had since it had 170k KMs, and it now has 320K Kms. It has been a great car, and although it has had quite a number of things go wrong, I still like it.
Repairs that I have had so far:
clutch + new transfer box
injector seals
FPR (twice)
injectors (and seals)
fuel pump
fuel cooler gasket
alternator
AC compressor
radiator
condenser
A/C fan
shock absorbers allround, and front turrets
I think that is all.
Now, I THINK that two of the bearings are failing.
Then... 3 weeks ago (approx.) I bought a L322 TD6.
It drivers brilliantly. It is SO much quieter and more comfortable than the D2.
Now, I have the chance of getting another L322 TD6 (probably for €3000). It has a fair amount of work to do on it. Most of it is cosmetic, but I know that one of the suspensions struts needs replacing, and the gearbox may need replacing.
So... what should I do? The D2 is really nice, but it doesn't compare (comfort-wise) with the L322. The D2 has proved to be pretty reliable, and is still actually in quite good condition. The chassis isn't too badly rusted.
What would you suggest?
Post #444345 12th Jul 2017 4:09pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
I've still got my D1, although sorned, I can't bring myself to part with it as it's been so reliable. I feel your pain. Laughing
Post #444353 12th Jul 2017 4:56pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Well, you know what they say about the Disco.
It means you can't quite afford a proper Range Rover Razz Laughing
Post #444464 13th Jul 2017 2:27pm
nebc100
Well... to be honest, I cannot afford either. I bought them both used.
The D2 was a 2003 TD5 with 170000Km in it when I bought it. It has now done 325000Km. Considering I only paid €6500 for it, I cannot really complain.
The L322 is also a 2003 TD6, but it had 280000Km when I bought it a few weeks ago. It drives REALLY nicely. Engine is gorgeous. Gearbox is fine, but GB oil pump failed, so had whole GB refurbished. It now drives beautifully!! The only problems with it now, are a battery drain from somewhere (think it could be the alternator since dealer stupidly fried ECU by connecting a 24V battery to the car. I will replace the alternator and then see).
The "other" L322 that I have seen, it nowhere near as nice as the one I have, but I think that I can get it for €3000.
The problems that I know of are:
bad leather wear on drivers door,
small hole (cigarette?) in back seat bench.
wear marks on some of the fake metal inside.
parking sensors not working
gearbox not OK (could simply need flush, but could need new gearbox)
one suspension airbag leaking, but all other working.
cracked front and back bumper.
cracked rear light glass
front windows cracked
front light wipers not working.
The seller wants €4100, but I am pretty sure that if I offer him €3000 in cash, he will probably accept.
Do you think it is worth it?
Post #444467 13th Jul 2017 3:06pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
^ Short answer, no.
Car plus reconditioned gearbox and new torque convertor will still leave you with a car that's cost only slightly less than a very good example which has had the gearbox done...... and you'd still have all the other faults to fix.
That's me looking at UK prices though and just my opinion.
Post #444468 13th Jul 2017 3:15pm
nebc100
I think the prices must be higher here because my L322 that is cosmetically in near perfect condition was €8000, and I had to spend €2100 on a new gearbox.
If I buy this other one for €3000, that gives me nearly €5000 to put towards repairs.
New window = €500
gearbox = €2100 (if it needs it)
back bench = not sure, but I could try to repair it using a kit from leather clinic.
rear lights off ebay aren't very expensive.
rear suspension = €500 (I can install it myself)
so... If the gearbox is not F*!+cked, I think that it will cost approx. €1500 to get it reasonable again, so total price of €4500. The bumpers can wait.
Post #444469 13th Jul 2017 3:20pm
Cooper1275
Ireland 2006 Range Rover Vogue SE Td6 Buckingham Blue
Id hold off and keep the Disco especially since you know what sort of a life it has had.
you could end up with a lemon. Evil or Very Mad
I know your pain tho, my old car (99 focus) was fantastic and far too good to scrap. In the end i gave it to a friend of mine.
Keep the disco and use it for the tough messy jobs. use the Range for the nice life Thumbs Up
Post #444474 13th Jul 2017 4:08pm
Weegie
I still have my D2 which I have had from new in 2003. It hasn't done the mileage that yours has but I keep it because it is a very good workhorse. It doesn't owe me anything (a bit more fortunate here as there is no VED so it only costs the insurance).
I think you are looking at a headache if you go for the other L322. The problems you mention are only what you know of. There will, in all probability be hidden others. Even what you mention will add up to a heavy cost.
In your position I would keep the D2 as the workhorse. John
GAP iiD BT-Sold
Post #444478 13th Jul 2017 4:53pm
rodp
No, what it means is after buying a nearly new 3.9 Classic Vogue for the wife in 1993 Range Rover went downhill rapidly. The diesel Classics were rubbish (under powered and noisy) ,later V8's suffered liner problems, the less said about the P38 the better, it then took several years for Range Rovers to become a decent buy again in my mind. The TD5 is out of the question, too frail and tempremental for me, the 300TDI is bomb proof (probably more by accident than design).
However, as someone who's always run series and Defenders my requirements are probably different to most RR drivers.
It's taken this long for me to accept RR's again and as it is at the moment I'll only buy TD6. I have another post up about what's the most reliable RR made and could possibly consider a later one if they're reliable.
At the moment the D1 is on standby in case the RR throws a shoe, in which case the jury is out on whether to repair it or go back to the faithfull old D1. Oh, and the D1 is very very tidy. Thumbs Up
Post #444482 13th Jul 2017 5:45pm
