Home > Technical (L322) > In tank fuel pump
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
In tank fuel pump
Hi guys I have been in touch with JLR with regards with the Fuel Pump in the tank, they then informed me that there are 2 present. I require some assistance with this issue and to identify where the second pump is located and what it is?
Steps Taken:
I have also taken the Primary pump from within the tank out and tested it upon a 12V battery to ensure it works to which we identified it does, yet we are still not receiving fuel to the fuel filter within the engine compartment.
The secondary pump is purring away and recently been renewed yet we still receive small spurts of fuel and the rest is just air.
(Also primary pump was filthy yet fuel had small amounts of contaminants yet when I dip the tank the fuel is shown to be clear leading me to think there are sediments at the bottom of the tank.)
Any assistance would be great. Thumbs Up
Post #444821 17th Jul 2017 5:52pm
#2 is the high pressure pump
#4 is the secondary pump..
from the WM. ... - .- -.
Post #444824 17th Jul 2017 6:18pm
Simran0211
Thanks Stan
sorry for being a pain but LOW SIDE PRESSURE SENSOR I'M also looking for the position of that aswell.
Thanks in advance.
Post #444827 17th Jul 2017 6:33pm
download the WM , its all in there...
link in wiki btw.. ... - .- -.
Post #444837 17th Jul 2017 8:11pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I've been doing some research for you, I believe that the low pressure sensor is part WKW000060, located on top of the fuel filter housing as shown in the picture below:
Not sure if this helps you?
Post #444846 17th Jul 2017 8:58pm
Simran0211
Thankyou all for your help will keep you advised of the progress 👍
Post #444888 18th Jul 2017 8:30am
Simran0211
Replaced both fuel pumps both the main one and the secondary one main pump was a pig of a job the pipe from the pump it self is plastic and flexible unfortunately you have to cut the black pipe to get the pump off replacing it was a nightmare Carwoods had the pipe but refused to he
lp Guy salmon Coventry were great but it was a part that they don't list so finaly I brought an alternative pipe from SERTC thank you for £2:00bargin 👍 Having slumed it on the buses to get there and back got a hot air gun then slowly bent the plastic into shape cut the required length heated the ends up and forced them on to the ends then after a few Censored words please please make sure you snap close the complete pump assembly because if you do not the pump will not work properly and the pump will just fail to pump fuel I had the pump out more times than having cups of tea Rolling with laughter my thanks go to the following people for The inspiration and help during this project goes to THE WIFE who said see I told you it was a pile off and should never of brought it give me inspiration to finish the project my daughter who help Immensely me Stan the site moderator and stacker for his help in supplying the drawing and many more that are on the site who have been though the pain as I have experienced and done a the write up £89 total price of the job
Post #445669 25th Jul 2017 8:52am
