Home > Maintenance & Mods (L322) > New driver side mirror glass advice required
johnb8538
United Kingdom 2014 Range Rover Autobiography SDV6 Fuji White
As prices range from £17-£180 on fleabay can someone advise me which model numbers are relevant on my broken glass mirror. Its a heated version but with lots of fluid running from the glass I'm wondering is it a light sensitive version as well?
According to the workshop manual I just need to tilt it out and upward to release, so reverse to secure I assume? I don't think I need to remove the whole housing from the door frame to replace just the mirror glass?
Post #444860 17th Jul 2017 11:34pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
One with liquid in is chromatic (think that's what it's called) they are expensive to replace, I replaced both my.mirrors for aftermarket ones (sadly cracking the passenger mirror when removing) I put on a nice matching pair of heated mirrors with blue anti dazzle effect
Post #444886 18th Jul 2017 8:59am
TJH1985
Chromatic have two sets of electrical connectors running to them, ones a black plug and the other connects directly onto the mirror.
We tried a few after market items, none of them dimmed so we ended up buying genuine.
Post #444923 18th Jul 2017 2:47pm
mjdronfield
Had to do mine last year....
You can get a non dimming one, even from Land Rover, for less than £40....
.... but it's a slightly different tint and won't match the passenger side. That would remind me how I cut corners, every time I drove the car...so I coughed up more like £140 for the proper one.
Just pull the old one off.
To fit the new one, I put some fairy liquid on the pegs and offered it up, after doing the connections of course... the push it in all at the same time, same pressure everywhere till it clicks in.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #444925 18th Jul 2017 3:15pm
johnb8538
Thanks folks. Having driven around for a few days with no drivers mirror you forget how necessary it is!
My mirror does indeed have the second electric connecter so that's that question answered, time to bite the bullet and choose a cheaper heated one or the properchromatic.
Post #445015 19th Jul 2017 11:03am
