Home > Technical (L322) > Help!!!!
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Help!!!!
Hi all,
Currently locked out of my FF at Watford gap services. The central locking hasn't worked for a while so I've been manually unlocking it on the drivers door. However.... Now the drivers door handle has broken!!!!!
Is there an emergency locked hidden under the passenger door handle trim? Or isit possible to prise the plastic backing dish out from the drivers handle and reach into the mechanism? NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #444935 18th Jul 2017 7:06pm
mjdronfield
Can you hold the unlock on the fob to get the windows come down and reach in....?
I am of course assuming your central locking is not working because of the car, not a fob issue..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #444936 18th Jul 2017 7:18pm
Post #444937 18th Jul 2017 7:29pm
mat777
Neither fob has worked for a while. I don't know why, as both of them light up when the buttons are pressed - I guess it's something wrong with the receiver in the car.
I really don't want to have to break a window! Big Cry
If I do have to, do all the doors unlock from the inside if the handle is pulled, regardless of if the central locking is on? If so, it would mean I could get away with breaking the little fixed rear window and opening the rear door, rather than smashing the huge drivers windows NW060
Post #444939 18th Jul 2017 7:45pm
mjdronfield
Depends if it's super locked. If it is, nothing will work - handles or button on dash.
Thinking on, scrub that, you must have unlocked it with the key, but it's just the broken cable....so it can't be super locked.
If you can somehow press the button on the dash....
The rear door should open if you can get to the handle. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #444940 18th Jul 2017 7:56pm
mjdronfield
You in the AA? Might be worth a try with their tools..... before breaking anything..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #444941 18th Jul 2017 7:58pm
mat777
I'm in the RAC, I'm already waiting for a breakdown truck due to overheating, this is just the icing on the cake.....
RAC telephone guy said it was a a specialist job which is not covered by my normal membership... Though I guess it's still cheaper than a new window plus fitting..... NW060
Post #444942 18th Jul 2017 8:00pm
if you turn the key twice it unlocks all the doors so even if the drivers door handle is broken you should be able to get in via the passenger door.... ... - .- -.
Post #444943 18th Jul 2017 8:04pm
mjdronfield
Or if that doesn't work, hold the key in the unlock position.... windows might open..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #444947 18th Jul 2017 8:22pm
mat777
Nope, still nothing Censored
Why does mine have to be so different to what is supposed to happen?! Censored Censored Censored NW060
Post #444949 18th Jul 2017 8:25pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
This is a very good reason to fix things when they break! When I got my fatty door lock didn't work at the first opportunity I stripped it and repaired
Hope your sorted now?
TAC not heard of specialist job, do you get your breakdown free with insurance or bank account?
Post #444969 18th Jul 2017 9:57pm
Broken window should be covered on your windscreen excess on your insurance - at least mine was - I was pleasantly surprised.
Post #444972 18th Jul 2017 10:05pm
mat777
Lesson learnt on fixing things promptly!
Many thanks all for your suggestions.
The rac bloke eventually turned up and managed to tease the door top open with a nifty inflatable envelope, then hooked the handle from the inside. The car is being dropped off to the garage tonight with strict instructions NOT TO LOCK IT until the handle is fixed! NW060
Post #444975 18th Jul 2017 10:34pm
p38arover
Australia
Have you tried resynching the keys to the car?
When I bought mine, one key didn't unlock the car. A forum member helped sort that with instructions on how to synch both keys.
See page 3 of http://www.fullfatrr.com/forum/topic3713.html Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #444986 19th Jul 2017 12:33am
