![]() | Home > Technical (L322) > Yellow engine check light? |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
I had the yellow engine check light come on today. Checked fluid levels - nothing wrong. Anything else I can do to clear it or is it a trip to the dealer. |
Crap fuel is the usual suspect......or something more sinister. Land Rover Addict
A check engine light suggests a problem with your engine management system, often relating to the emission side of things.
Lambda Oxygen Sensors are a common culprit but your car is quite new for CAT damage....
Safe to drive to the dealer? It came on when I was about 5 miles from home (steady not flashing). Dealer is about 8 miles away. |
If engine running as normal I would say yes. |
Very kind offer. I am near Cambridge.
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
keep an eye on your temp gauge just in case.
if you were closer to london i could of checke it and see what code came up, i ran low on petrol once just about rolled into the station, spluttering and my engine light came one. but after a day it went off, the next my scanner turned up..but no codes stored.. V8 facelift Range Rover Autobiography 22" wheels.
Nothing drastic. Some fault that required new software to be downloaded. £100 and an hour of my time.
did you ask what software was upgraded, i find it hard to believe just because there is a software update for said module and that they want to charge you for it, why should your car need it..
I can perform this software upgrade on your car for a mere £75. I wont tell you what it does or anything about it. You'll just have to believe I've done it - and in reality all I've done is clear the fault code.
I am not sure of all the details. IIRC, the fault code was that one of the cylinder banks was running hotter than the other, showing a petrol mix fault. There was a service bulletin that recommended a software upgrade for the ECU that would prevent the fault from reoccurring. I took that to mean that the cylinder bank wasn't hotter, merely that the ECU had gotten confused and that a software update prevents this from happening again.
have you got the fault code, is it on the invoice? if so google it. 2004 black Vogue TD6 |
