Home > In Car Electronics (L322) > Speedometer Needles Removal
Patrickthier
United Arab Emirates 2002 Range Rover SE 4.4 V8 Alaska White
Hi,
Small issue on the 2004 L322
I bought a LCD repair from AK speedo, some pixels faded some other gone.
Everything went well until I reached the 4 needles, how do I remove them SAFELY?
I watch many videos, but they all contradict each other!
I'd like to repair the LCD not to snatch the needles & the motor behind!!
Any safe instruction?
Thanks
Patrick
Post #445130 20th Jul 2017 11:51am
didn't know that the needles had to come out....some on the forum have done this type of repair so i'm sure someone will come along and advise.. ... - .- -.
Post #445133 20th Jul 2017 12:00pm
so i have found this,
and theres loads of threads that should help you here,
http://www.fullfatrr.com/forum/search.php?...rch_time=0 ... - .- -.
Post #445142 20th Jul 2017 12:43pm
p38arover
Australia
I thought there is a little slotted tool to hold the shaft while the pointer is removed.
Here we are:
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #445143 20th Jul 2017 12:48pm
Patrickthier
Thanks,
I'll order the pixelfix tool and let see!
Post #445150 20th Jul 2017 1:43pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
The only problem I can see with this is, how do you re-calibrate the speedo and other gauges to read correctly when you re-assemble it all.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #445375 22nd Jul 2017 5:16pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
The AK Speedo kit doesn't need the needles removing, it comes with a drill template and you drill through something instead!
I've got the kit at work but haven't had the balls to fit it yet!!
Post #445405 22nd Jul 2017 8:21pm
Patrickthier
Drill & Balls, not sure of the combination.
Better to get one in working condition on Ebay, I'll go that route.
Post #445462 23rd Jul 2017 10:56am
Gold Ranger
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
i got the AK Speedo kit doesn't need the needles removing but you need patience and a steady hand
even with the template where you drill the holes measure twice and remark the template and start off with a pilot hole then work your way up drill size and then you can undo the 4 screws
make sure you clean the circuit board contact thoroughly so they are nice and shiny
get some thin sellotape and carefully line up the contacts and then press down rubbing across the ribbon - semi assemble and test before putting it back together
ive added a before and after photo
Post #445463 23rd Jul 2017 11:14am
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Any chance of a picture of the template? I got mine from ak a while back just not got round to stripping the dash
Post #445464 23rd Jul 2017 11:21am
Gold Ranger
as you can see by the template photo the actual hidden screw locations are indicated by the pen marks at the very top of the paper
to get to some of the holes to drill you have to lift the front of your dial panel but dont put too much force on it and try not to catch it with the drill
also the third hole along left to right is kinda awkward but doable
Post #445470 23rd Jul 2017 12:19pm
Miserable Old Codger
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
This might be useful for anyone replacing pixel ribbon in the future.
I have a l322 that I imported from Japan and although it did pass the MOT with a KPH speedo I wanted to replace the dial markings with a MPH facia. These can be bought on various sites on the web for about £90.
I did not want to buy a complete cluster unit either second hand or new because (A) the I have less than 40k miles recorded on my car (although it is shown in Kilometres its easy to convert to miles) and (B) another unit would need to be programmed to the vehicle.
I found both of the previously posted youtube pixel links while looking for instructions but they did not show how to remove the needles. So in my infinite wisdom I used a link for a 2005 RR Sport. Seemed easy so I just followed the instructions and pulled off the first needle. Yep! infinite wisdom? look similar but different and the l322 (BMW) has different stepper motors so totally wrecked the thin ribbon spring that returns the motor to 0 (these motors are the same on speedo, rev counter, fuel and temp gauges ) Eventually found a link on BMW forum for removal of needles.
Actually akspeedo do a tool for removal of needles (£11) but do not show it on the pixel replacement film instructions.
It is easy with the tool and no chance of damaging anything with that drilling template when replacing pixel ribbon.
Here is a couple of links with akspeedo.com the tool is extra to the tape... with pixelfix.net the tools come with the kit.
I have bought my tool from akspeedo.com because I do not need to fix pixels and they are in UK. So I cannot recommend pixelfix.net but they seem ok.
Luckily I did not buy a new dial facia because it was cheaper to buy a full cluster for ebay with faulty pixels so I don't need to pay for new speedo motor, but my decision to do that was just luck..
http://www.akspeedo.com/range-rover-lcd-pixel-repair-shop.php
http://www.pixelfix.net/eng/rover.html
Post #479534 28th May 2018 2:06pm
