![]() | Home > Technical (L322) > Chasing a nearside pull |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Right well those that have seen any of my other posts will know that I am pretty anal about the FF running tip top so I have a pull to nearside slight I may add and also about 5degrees right hand down on steering to keep her straight- tested on flat road straddling road middle same road used many times. So have decided to just replace both front lower arms and control arms and track rod ends - they feel ok but you never know = question is there anything else I should be looking at ? |
I had similar.
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
Sticky brake caliper? I have one at the moment! |
Started by having it Hunter Aligned so I knew it was spot on and it did improve so replaced all the tyres they were below 4mm so I tend to change them then anyway Interesting about the steering weighting left to right and back have it on the ramp now so will go and check that
Meant to say new front shocks/bags and pump last year new backs last month |
Thanks all glad to report all sorted Not sure what the culprit was bit of wear on one lower arm the track rod ends hadn't been replaced by me and I have done the last 90k so they could have contributed full hunter tracking had rears out fronts were obviously a mess all tracked up drives like new
