![]() | Home > Technical (L322) > Bad vibrations |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35759 ![]() ![]() |
i'll stab at this and say its the transfer box, hopefully i'm wrong...doesnt sound like the servotronic valve on the steering rack as i have just replaced mine and my symptoms were different [heavy steering].. ... - .- -.
Could be a number of things based on what you say. Most likely would be burnt autobox fluid and this does cause vibration through the gears and slow changes.
just found this on another site which 'could' point to the servotronic valve...
Landrover Mad Member Since: 04 Jan 2011 Location: N.Ireland Posts: 35 ![]() ![]() |
Hey Max,
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
I had slow take off from cold recently. It would take on occasions up to 8 seconds before I got forward motion. 1st gear Sprag clutch was the issue. Autobox rebuilt before it left me high and dry.
max abbi Member Since: 19 Oct 2010 Location: Newtownabbey Posts: 18 ![]() ![]() |
Thanks guys for the the replys and pm's. I think I have found the culprit, a sticking drivers side front brake caliper. i knew the front discs were slightly warped and were due for replacement anyway but todayby chance I felt the temp of the front wheels and the drivers side wheel was red hot ! So I have ordered new discs and pads and a new seal kit for the caliper. Will let you know how it goes. |
I just had a similar problem on the D3 rear offside wheel - it was red hot to the touch and diagnosed as seized piston requiring new piston & seal kit but not disc or pads as these were OK |
SORTED ! |
glad my diagnosis was wrong.. |
Me too |
definately me three |
L7APK Member Since: 14 Jan 2011 Location: Lancashire Posts: 25 ![]() ![]() ![]() |
max abbi was the problem in the end down to the caliper ?
Had a similar problem with a rear brake caliper seizing and slowing it down intermittently after a few kms. First thought the worst, gearbox problem but luckily only the caliper or pads as the calipers are fine now. Car had been sitting still for 2 years after import here. Brakes all cleaned and new pads and problem is gone. MY 2010 5.0 SC Galway green and sand interior!!
