Home > Maintenance & Mods (L322) > Windscreen top seal removal |
Ollie7195 Member Since: 11 Dec 2016 Location: Somerset Posts: 74 |
As the title, I have a leak from the top of the windscreen in my l322 I have managed to get the roof rail strips off to find lots of crud built up near the windscreen but the leak is under the main seal, does anyone know how to remove it? will it require replacement if i take it off?
22nd Jul 2017 4:11pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
RAVE isn't much help:
22nd Jul 2017 4:41pm |
interesting...if only it was that easy! there is plenty of room to get to the ends of the seal now the roof rail strips are out of the way so hopefully the side pillars don't need to come off! the previous owner did a terrible job of firing mastic all up the inside of the windscreen that just moved the leak from the corner to the rear view mirror! ive cut all that out as best as i can but it would appear the best way to cure the leak would be to stop it getting past the top of the screen...which would be easy if not for the finisher, sunroof drains are fine easy check as my headlining still isnt in yet!
22nd Jul 2017 5:01pm |
