![]() | Home > Technical (L322) > Height sensors |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
Recently fitted rear aftermarket ones to a mates fullfat all is well, they are not hard to change, get an aftermarket one should it fail then replace with original, aftermarket ones around £20 and 30 mins to change |
So, any links for the £20 front height sensors, then? (were they for the early L322 with Xenons/6 pins?) .
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
I wonder the same, the cheapest one I could find that looked any good was £45, I thought it went faulty after a few days and bought a genuine one for around £80, turns out the problem was with my diagnostic tool!
The back ones purchased were £20 off guessing the fronts are more? Havnt looked them up didn't think there would have been much difference from back to front |
Hi Lukie - there is a big difference in price, normally double |
JPJ64 Member Since: 23 Jun 2017 Location: Newcastle upon Tyne Posts: 49 ![]() ![]() ![]() |
Thanks for the advice. As I need this in a hurry, and will only have an hour or so to fit it and calibrate the suspension before heading off on holiday, I have bit the bullet and gone for the genuine LR part. Here's hoping its as simple a fit as it looks. |
