![]() | Home > Maintenance & Mods (L322) > DRL wiring |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
for the the ignition live take a feed from the engine fuse box ..
| scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391
Chris, I'm keen to fit DRLs to mine aswell.. any chance you could share the detail on how you ran the wires etc? Current:
| Druboo Member Since: 04 Jun 2017 Location: Wiltshire Posts: 12
I would prefer them in the headlight just like L405 but that might be too ambitious unless I can get my hand on cheap replacement ones. Current:
| TOF Member Since: 13 Mar 2013 Location: Gloucestershire Posts: 53
Well, i fitted the Osram DRL fogs yesterday. They are really good. I wired the white wire (which turnes them off when the headlights are on) to the blue / grey wire are recommended by the guy who kindly replied to my post. This was a great help to me instead of testing all the wires. As it was difficult to get doen to the plug on the headlights, i tapped into the wiring loom next to the fuse box on the left side of the engine bay (Drivers side UK). There is an earth point to the body just in front of the fuse box, and a thick red battery love in the fuse box.
Here is the DRL fog, covered with Lamin-x |
That looks good mate.. post some photos with the DRLs on. Where did you get the Osrams? any link Current:
Will do. I bought them off camtech craig. |
| shinchan Member Since: 05 May 2015 Location: santiago de compostela Posts: 114
| WB Member Since: 26 May 2016 Location: London Posts: 303
Hi, reviving an old thread I've ordered some combination DRL/Fog lights similar to these. The Fog light part uses the existing connector then there are two wires that are for the DRL. My car is a 2010 so has the standard not very bright factory DRLs - I'd like to keep those and add the new fog DRLs too. I assume that I need the same connections mentioned above but just wondering if I can take an ignition live from the existing headlight wiring? also does anyone know if the 2010 headlights the headlight on wire is still blue and slate or did that change? I think what I want is for the new foglight DRLs to go off when the headlights go on rather than to stay on and dim. Many thanks
does this help?
Thank you Stan, much appreciated. Do you think it would be pins 14 and 11 that I’d need. I’m struggling a bit with the logic of what the two angel eye wires need to connect to.
personally i would buy a drl switch and wire that to an ignition live and most drl switchs have a function where you wire in a headlight feed to it so when the headlights go on the switch switches off the drl..
