![]() | Home > Technical (L322) > 4.4 TDV8 Suspected electrical issue |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
#1 is what mine did when the battery was failing and unable to hold proper charge. If the battery is original then maybe time for a new one. |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
I've had the starter just give a click now and again, but start no problem most of the time.
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 177 ![]() ![]() ![]() |
I have just put a multimeter on the battery. 12.09v before it was started (it did a 100 mile run yesterday), 14.45v when running and then back down to 12.18v very quickly after stopping it again.
I very recently fitted a Varta G14 Start/stop AGM. It gets back to a float charge very quickly which is great for short runs. |
Looking at the battery fitted to it now it is a Land Rover part but is actually a Varta G14
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
it appears that bms has to be reset Sam,
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 230 ![]() ![]() ![]() |
I don't know specifically on Land Rovers but on other cars I have looked at then the car would start without the BMS reset but they didn't recommend leaving it too long till resetting it as you could damage your new battery.
