Home > Maintenance & Mods (L322) > L322 tdv8 body removal
MattC
United Kingdom 2011 Range Rover Vogue SE TDV8 Alaska White
Afternoon all,
My car has been in the garage for 4 weeks trying to diagnose an oil leak and to have the suspension removed, overhauled and bushes etc replaced. The garage are saying that they will need to remove the body to get to the rear of the engine block- i though this was only possible on the RR sport? It's a 2011 4.4 TDV8...
Post #445706 25th Jul 2017 3:16pm
You could probably sell tickets, ice cream and rent deck chairs for folks to watch !! (Depends whether it is on your money or theirs?)
Definitely cannot remove the body, remove it from what - the engine? - perhaps round the other way .
Post #445710 25th Jul 2017 3:24pm
MattC
Thanks- just wanted confirmation!
Post #445717 25th Jul 2017 4:03pm
Baltic Blue
Your oil leak at the back of the block sounds like the Oring failure detailed in a post by Craig.
Also full suspension refurb on a 2011 ?. seems a bit premature.? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #445718 25th Jul 2017 4:05pm
MattC
It's the Overnfinch spec with 22's, so the suspension gets a rough ride anyway. Also the previous guy who tackled the oil leak cleaned the block down with brake fluid and i'm conscious of the damage this may have caused to the rubber elements under the hood.
Does anyone know anyone local to Surrey who would look at the o-rings?
Post #445782 26th Jul 2017 8:46am
mpirie
Agreed, sounds like the small O rings for the turbo feed pipe at the back of the oil cooler which sits at the rear of the engine.
The O rings get brittle and allow oil to blow past under pressure which then runs down the bellhousing.
I had to do mine at 55k.
Post #445787 26th Jul 2017 9:24am
This body has been removed.
From everything.
Now it's much easier to get to the engine.
Where ever it is.
Post #445875 26th Jul 2017 8:10pm
Rob99
Rolling with laughter Rolling with laughter 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #445926 27th Jul 2017 12:53pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Laughing
Post #445932 27th Jul 2017 2:32pm
Laughing @KurtVerbose Thumbs Up .
Post #445943 27th Jul 2017 6:55pm
