Home > Maintenance & Mods (L322) > 10-12 doorcard trims
Danwilderspin
I've won a set of 2010 door cards on eBay but just realised the trims that's next to the handles is missing - any ideas what the cheapest option here is? Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #445764 25th Jul 2017 9:39pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
you will need to find a way to create some weakness in the new door card at the top as on pre 2007 vehicles the side impact airbag is attached to the door behind the door card above the arm rest, where as on post 2007 vehicles this was moved and built into the side of the front seats.
to allow for this, pre 2007 door cards are made from a cardboard type of composite material to allow the airbag to tear through when is is deployed where as the later door cards are made from solid plastic and won't allow the airbag to break through in an emergency.
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #445772 25th Jul 2017 10:36pm
Danwilderspin
Ok cheer matt - any idea re the trim strips can't find them anywhere I'd even be happy with a 3D print Smile Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #445776 26th Jul 2017 12:05am
mattstevenson2005
When you say trim do you mean the speaker cover or below the arm rest where the wood insert goes?
Matt Current
Post #445793 26th Jul 2017 10:31am
Danwilderspin
Hi matt
Below the armrest...
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #445828 26th Jul 2017 1:47pm
mattstevenson2005
You will have to keep an eye out on eBay, they come up every now and then.
Matt Current
Post #445835 26th Jul 2017 2:42pm
dan_uk_1984
Aren't all the speakers and things in a different place?
Also as mentioned, the Air Bags - in the event of deployment it's going to literally explode shrapnel into your car Shocked
Post #445838 26th Jul 2017 2:55pm
mattstevenson2005
Bass speakers are in the same place, mids are in a slightly different place but same mounting, airbags already been mentioned.
Matt Current
Post #445851 26th Jul 2017 4:52pm
Danwilderspin
TBH I have baby seats in the back so I should really disable those airbags anyway is there a proper way of doing it? Or just unplugging and leaving the light on? That's would sort half the problem... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #445852 26th Jul 2017 4:53pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Just came across the thread. The rear doors don't have airbags built into them like the fronts.
If you do disable the airbags in the front doors you can install a resistor on each wire connection to tell the car that the airbags are still there even when not. Seems to be a common mod with sports cars etc. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #477536 4th May 2018 3:30pm
The airbags are only in the front doors... Thumbs Up
Please think about the insurance implications of unplugging any airbags! Whistle
Post #477559 5th May 2018 1:09am
