![]() | Home > General > How Many Miles can a TD6 Reasonably be Expected to Do |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Considering that the boys from Highways England run their SDV6 Disco 4's to 3 years / 250,000-320,000 miles, I'd never let a few miles stand between me and keeping a decent car! I'd push on to 200,000+ miles if possible |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Tempting fate:
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
At the end of the day, if the rest of the car is in good order then these can do good mileage no problems. The gearbox will go bang at some point, it's fairly inevitable, but if you get another 20-30k out of it first then great. If it goes tomorrow, then you will have to spend that now, and you will be set to 180-190kI would have thought.
Clive603 Member Since: 21 Jun 2016 Location: Sussex Posts: 35 ![]() ![]() ![]() |
Thanks for the advice gentlemen.
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 ![]() ![]() ![]() |
Mines got 142k on it and the gearbox is one of the few things that hasn't given me problems.... QUID FACIUM TIBI
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
My first 2002 HSE TD6 was still going strong with over 135,000 on original gearbox when I sold it to a mate! best FFRR i have ever had. Not a thing went wrong in 3 years. |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
Sold my TD6 at 168k miles this time last year. It was still running ok but really needed a couple of new injectors. It would fail to start after a long run towing until it has cooled down a bit. No problems at all with transmission. Perhaps I was lucky! Current: 2010 Range Rover L322
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1231 ![]() ![]() ![]() |
My gearbox went pop at 136k so the originals can do that, now that's sorted the engine and rest of the car still drives really well even with close to 170k on it.
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
I don't want to put a downer on the situation but obviously there is two sides tk every story!
The main consideration is a lot less complicated that it was 20 years ago. As long as the body doesn't rot out the car can go on pretty much for ever. Mechanical components can be changed relatively easily but the main things (costly items) are the body (welding), the engine (reconditionable) and the gearbox, also reconditionable and a known weak point on the TD6.
@mpcg
@mzpicg:
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Couldn't agree more ![]() |
