![]() | Home > Technical (L322) > Newb with possible 4.4v8 purchase with gearbox fault |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
Hi Simon & welcome to the forum.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 816 ![]() ![]() ![]() |
Hi phil , going off your chart its a 53 so must be a ZF 5 speed |
The 5HP24 is very straight-forward to repair. I must admit, though, that I haven’t seen that particular issue before. 4th gear uses both the A & B clutches. The A clutch is also used in 1st, 2nd & 3rd so it’s unlikely to be that. Sounds therefore like there may be an issue with the B clutch? Very unusual, though. This is the repair manual for the transmission if you want to have a look through it :
Thanks for the info so far phil , ive just looked at the add again , it says it wont go into 4th gear , dont know if that helps at all but yiu seem to suggest if i can get it at a good price it will be worth a gamble ?
Oh i meant to add the car has done 110k miles |
If you look at the typical parts required for a 5HP24 rebuild i.e. overhaul kit, re-manufactured torque converter, b-hub/c-drum bearing, rear casing seal, output shaft O-ring, 3 steel pipes, A-clutch circlip, 11 litres of fluid & a filter - you’re looking at a minimum of £750 for parts. Would it make sense to spend this amount, taking into account the purchase price of the vehicle?
I think there lies the issue , buy it and repair whats needed to make it road worthy or buy it and refurb the box completely ( taking it off is a 'mayaswell' cenario ) the current owner must be aware of the cost to retail of a box refurb , hence the sale |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
It depends on how much of a bargain it is to start with I suppose. There is nothing that can't be fixed with a hammer😜😜
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
If the car is cheap enough to buy and your not afraid to swap gearbox do that, second hand box can be had for £600 ish |
And in case you need a reference point for a re-manufactured unit, I charge £1375 +VAT, including 11 litres of genuine LT71141 fluid and a re-manufactured (by JPAT) torque converter
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Sorry to hijack , but if your reading thia Phil , what do you charge for a 6hp ( for a 3.6 tdv8) please ? 2015 4.4 AB
well after all that . It got sold , will have to search again but out of interest is the td6 with a punt with a similar issue ( yes im aware the gearbox was made by kinder egg ) |
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
They're all “worth a punt” if the price is right and you're happy with the model.
can this thread be closed please with a thankyou to all that inputted info , ive bought a derv L322 that hasn't got a gearbox issue ( yet ) |
