Home > Duckworth Parts > Some prices please
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Some prices please
Dan, please can you give me a price for the following for a 2003 L322 (V8 if it makes any difference):
1 off rear sub frame mounting bolt (the one that goes through the bushes, managed to strip a thread!)
2 off rear hub top bushes (the outers) plus associated nuts, bolts and eccentric washers.
2 off rear anti-roll bar drop links.
The two rear brake pipes that run from the callipers up the upper suspension arm and join to the rest of the system just in front of the axle (both sides please) along with the 4 plastic clips and bolts that hold the pipes to the upper arm.
Thanks
Roy. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #445491 23rd Jul 2017 3:23pm
rvbush
Have I offended you Dan? Sorry to hassle, but parts needed as MOT failed please. Drives:
Post #445737 25th Jul 2017 5:21pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
I always Private Message Dan as he doesn't then need to look to find your request Smile GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #445790 26th Jul 2017 9:59am
rvbush
Ok, thanks for that. Drives:
Post #445808 26th Jul 2017 11:54am
duckworthparts
Site Sponsor
Sorry Roy completely missed this post Embarassed
1 off rear sub frame mounting bolt (the one that goes through the bushes, £4.00inc vat
2 off rear hub top bushes (the outers) plus associated nuts, bolts and eccentric washers. £90.00inc vat
2 off rear anti-roll bar drop links. £60.00inc vat
flexi pipes or the copper ones? if the latter I won't send shaped pipes via courier due to damage risk You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #445809 26th Jul 2017 11:59am
rvbush
Hi Dan, the pipes are the ones that actually connect to the callipers, they are mostly flexible, but have 2 small sections of steel in them (this is the bit that's rotted, big surprise). They go from the calliper, up along the top suspension arm and then connect to the main solid pipes on the body just in front of the axle on each side. They are held onto the suspension arm by two clips each side with allen headed bolts (need the clips and bolts as well please).
Thanks.
Roy. Drives:
Post #445813 26th Jul 2017 12:05pm
duckworthparts
Site Sponsor
Thanks Roy classed as the flexis then, they'd be £90.00inc vat for both and fittings You can paypal direct using - www.paypal.me/duckworthparts
Post #445814 26th Jul 2017 12:08pm
rvbush
I make that total £244, do you agree? Drives:
Post #445817 26th Jul 2017 12:16pm
duckworthparts
Site Sponsor
Yes that is correct Thumbs Up You can paypal direct using - www.paypal.me/duckworthparts
Post #445823 26th Jul 2017 1:04pm
rvbush
Dan, I just about to PM you with some info. Drives:
Post #445827 26th Jul 2017 1:32pm
