Home > Maintenance & Mods (L322) > Steering Wheel Vibration
mercs600
England 2002 Range Rover Vogue Td6 Java Black
As the title says - when going down hill and braking I get vibration through the steering wheel as is the disc's are warped. I first had this 2000 miles in after fitting cheap discs and pads. Bearing this in mind I fitted new Pagid discs and pads , cleaned and greased the sliding pins and before fitting the discs , cleaned the surface to ensure no high spots. I have also fitted another set of wheels and tyres but I am still getting this issue. Normal 'everyday' braking is fine so Im at a loss as to the problem ! Any advice gratefully recieved. Question
Post #445761 25th Jul 2017 8:10pm
sako243
Downhill implies something on the front axle. I'd give the bushes a good inspection. You can get similar behaviour on a Defender when the panhard rod bushes are going, which the FF doesn't have but other bushes can contribute.
Quick check of tyre pressure won't go amiss. Ed
Post #445762 25th Jul 2017 8:24pm
mercs600
Removed , checked and DTI'd the discs - all ok. Ensured re-seated flat etc and greased caliper pins. All checked out ok. Wheels torqued correctly and tyre pressures correct. Checked bushes as far as I can , but , what bushes are likely to introduce the wheel shaking as described ? Even removed and redid the rear brakes ! All were changed for Pagid discs and pads all round at the time so at a bit of a loss for now Trawled the internet but no luck so far ! Sad
Post #446033 28th Jul 2017 3:41pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
What size wheels are you running?
If over 18", the td6 is prone to vibration from larger type wheels.
18's are standard on the td6.
I get vibration off mine when moving from access height to standard, their doesn't seem too be an answer too it.
greg.
Post #446048 28th Jul 2017 5:59pm
mercs600
Just fitted TDV8 19's - still does the same with stock 18's so unfortunately it seems to rule the tyres and rims out of the equation Sad
Post #446092 29th Jul 2017 7:19am
