![]() | Home > Technical (L322) > Power Steering failure on holiday...heeellppp |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Find the reservoir check hoses are attached. Follow the hoses down and see where you can see wetness/fluid. No obvious leak will mean it is at the rack or pump, may be hose come off rack or pump. Unlikely to be pump seals but may be rack seals if held on full lock?
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
n1cktdv8, the reservoir you can pull up and out so to make inspection easier, it just slides in and out the holder.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
with all that lock to lock i'd punt for a hose coming off hence the large fluid loss.. ... - .- -.
