![]() | Home > Maintenance & Mods (L322) > Cost of new DPF? |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
He doesn't post often, but little gems of advice like this, remind me how much I miss your contributions Craig. G reg 2.5VM Vogue Portofino red 1991- 1999
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2723
+1 mr blue |
| 160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 461
Hey everybody Craig's back (well back-ish). Welcome old chap. Don't be a stranger. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
| Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409
thanks all for your help/advice.
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
Many members 4.4 tdv8's have done over 100k miles, but I don't remember anyone saying they have replaced their DPF. G reg 2.5VM Vogue Portofino red 1991- 1999
After getting the car back from the main dealers who refused to do anything except wanting to fit a brand new DPF, I tried what Craig said when I got home. Sadly hard resetting the battery made no difference. I tried 3 times and each time when reconnected the car went straight back into the RED DPF message and limp home mode so impossible to do a passive regen. Cant find any DPF cleaning specialists near me so I think I'll see how easy it is to take it off myself and courier it to one. If it's not an easy job then I may have to bite the bullet. |
I have found an alternative picture for you.
| Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1483
I'm not able to check this myself at the moment, and don't know if it's possible, but can the IID tool force the car to do a regeneration cycle?
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
mobile cleaning???
Having now read that the whole exhaust system including cat, DPF , and rear silencer are made from stainless steel, I can now see where the £2500 replacement price comes from, but surely it also makes more sense to get it cleaned somehow?? G reg 2.5VM Vogue Portofino red 1991- 1999
Thanks Stan - as mobile, they can only trigger an active regeneration the same as LR tried but failed. Passive or active regeneration can only clear soot built up. The problem is not soot but soot that has previously failed to burn then becomes ash. The ash then collects in the DPF which can't be burnt off so the DPF has to be removed from the car if cleaning is to be successful and even then apparently there is no guarantee.
Well, now I've just uncovered something that may change this. Yes - as I found out this morning, from new manufacture, the DPF is part of an "all in one" exhaust. But having just read the second page of what you attached earlier Blue, it would seem (I'm waiting for duckworth Dan to confirm) , that replacement DPFs may not include a full system. You actually have to CUT out the centre section of the old DPF/system, mount the new DPF and pipe and fasten at each end with Sleeves and clamps. mmmmmmmm |
| All times are GMT |
