Home > Maintenance & Mods (L322) > Fuel Pump 4.4 V8 Petrol
jammez
I have a 2003 L322 with a petrol 4.4 v8. Last year the fuel pump packed in with no warning (it's done 160k so I thought that was quite reasonable!)
I replaced it & the fuel filter (brand new ones) and within a few weeks the new pump was starting to make a whining noise which got louder over the following weeks. With this kind of noise usually being a symptom of the pump about to fail I thought I'd just got unlucky with a bad pump. The supplier replaced the pump without any problems and once the replacement was fitted it was fine for a couple of weeks then the whine is back louder than ever! It's louder than the engine & the air suspension pump combined!
The pump wasn't the most expensive available at £100 so am I just buying a crap part or would there be something else causing them to whine?
Any thoughts greatly appreciated
Cheers
James
Reply
Post #446322 1st Aug 2017 2:43pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
I had the same noise after I fired a cheap pump. It's still working a year later though. The noise is louder as the fuel level falls. When the tank is full there is no noise. I just decided to live with it and turn the music up Wink
Post #446324 1st Aug 2017 3:57pm
jammez
Thanks for the reply. I think I'll change it out for a better quality one. Any recommendations for a source for just the pump on it's own rather than the whole assembly?
Post #446505 3rd Aug 2017 12:19pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
LR014301
https://www.lrdirect.com/LR014301-Pump-Assy-Fuel/?keep_https=yes
http://www.island-4x4.co.uk/range-rover-l3...mp;sort=3a
Inner motor or Pierburg..
Of go OEM, and would just replace the motor its very easy and guides online on how to do.
personaly i went with 16116752626 (bmw part number)
Genuine Bosch.. Links i am linking are just to show products.
http://www.ebay.co.uk/itm/Genuine-Bosch-09...1170266388 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #446555 3rd Aug 2017 5:38pm
jammez
Cheers, I think I'll give one of the Bosch one's a try
Post #446600 4th Aug 2017 8:56am
Edisback
England 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I have now had the same problem (with noise from the replacement pump) twice. 1st time round I replaced just the pump with cheapest from Eurocarparts & 2nd time round whole assembly (incl pump) cheapest from Eurocarparts
both started getting very noisy after few weeks
unsure of the manufacturer (of above) but assuming not Bosch... so I will buy the Bosch BMW part and let everyone know if the noise goes
Post #520851 6th Jul 2019 2:14pm
