Home > Technical (L322) > Air Con
forever
Air Con
Just a quick query before i go and get it re-gassed, is there anything else i should check first? It was working without issue yesterday, but now no cold air at all...
Post #446494 3rd Aug 2017 9:18am
Clivefog
It will decline slowly, so it was fine yesterday I'd check the switch/wires ensuring the pump clutch is working first.
Post #446497 3rd Aug 2017 10:28am
forever
I do hear the clutch engage when i press the air con button on and off....
Post #446498 3rd Aug 2017 10:59am
Clivefog
Does the clutch stay engaged?
If it does that would indicate ample pressure.
Perhaps your idea of a £40 re gas will cure it/show up what is wrong?
Post #446504 3rd Aug 2017 12:16pm
any reputable re-gasser will be able to do a leak test to see if or where your system is leaking... ... - .- -.
Post #446506 3rd Aug 2017 12:20pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I had a leak from a pipe the runs along the drivers wing.
Where it was clipped to the body it had rubbed a hole!!
Post #446551 3rd Aug 2017 5:13pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Paul - same as mine, the pipe arrived from Duckworths this week and is currently on the table, will probably go onto the car tomorrow evening!
Worrying thing is, Mr Clutch didn't seem to pick this up on a leak test, yet the mobile air con guy picked it up straight away less than 24 hours later...
Post #446585 3rd Aug 2017 10:59pm
