![]() | Home > Maintenance & Mods (L322) > Cost of new DPF? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
crikey that's lot of fecking about just to get this sorted..... ... - .- -.
i've spoken to my son who does this kind of thing in his garage and he siad that it can be done on the car by putting cleaner in and keeping the engine revved up for around 15-20 minutes....
the computer cant tell!!!!
| Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3884
If it helps, Iwas told that the turbo drain mod applies to ALL L322 4.4tdv8's and even early L405's .
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
I don't think the drain mod is a recall, even though it is a design fault. I think if you have a warranty and it is causing problems they will do it, but otherwise (like me) it's the owner's problem, you might have to bite the bullet of the eight hours work. Another reason not to buy another diesel. Only Range Rovers since 1988 |
Thanks - Blue - I have the TSB.
I had a similar experience when the brake recall was happening in the US. My car was in the VIN range, I called the dealer and LR Customer Relations, both told me "it's not on the list" and that was that. I was not happy about it, but waited, and sure enough LR did recall it maybe six months later, an illustration perhaps of the effect of the fear of US litigation on their priorities as the safety aspect would presumably have been the same in both countries.
Stan,
i think your correct re the extra fuel Michael but its when that fuel is injected into the system..i believe it goes in after the initial spurt and that helps the exhaust get hotter and hence the soot gets burnt off..
Like Baltic Blue my understanding is the drain mod item apples to all 4.4s until modified retrospectively or built differently, i.e. later 405s. If you want to speak to the service manager who told me it is Dave Fortune at Lloyd Land Rover in Kelso, 01573 227345, maybe a bit far away to be an alternative for you though. Only Range Rovers since 1988 |
My understanding is that this is the "active" regeneration as opposed to passive. Active is only performed when plugged into the diagnostic computer which triggers the regen. The passive regen changes nothing in the fueling and is only the owner performed regen on the motorway blast etc that clears the soot. |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Active vs Passive detailed here:
^ link says once you see the RED warning:
| All times are GMT |
