Home > Technical (L322) > Strange temperature/voltage etc reading in live mode
nebc100
Luxembourg 2003 Range Rover SE Td6 Monte Carlo Blue
I was worried this morning that the headgasket on my TD6 has failed, so I wanted to check live values with engine on (coolant temperature, air temperature etc).
the air temperature was shown as: -52876C
Voltage was: 16086V
air pressure: 165092KPa
Coolant temp: 162944C
Now... since the temperature gauge was not in the red, I somehow think that the coolant temp is wrong. There are other reasons I don't believe the coolant temperature, but I don't need to go in to those!!
Do you think that this is a problem with the Tool, ECU or what?
Thanks for your comments.
Nick
Post #446612 4th Aug 2017 12:35pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
What tool are you using?
Post #446623 4th Aug 2017 2:49pm
nebc100
IID Tool
Post #446624 4th Aug 2017 3:02pm
nebc100
Here are some photos of the strange readings:
Post #446629 4th Aug 2017 3:58pm
Stacker
Oh that is very strange!
Unfortunately i'm not too familiar with the iid tool, however if you were using an iCarSoft I would have said that i've had incorrect readings from the device before and it can't be trusted too much.
Hopefully someone will be along shortly that will be more help than me!!
Post #446630 4th Aug 2017 4:00pm
