Home > Maintenance & Mods (L322) > Alternator change still low volts - help needed
Sandyt
Right Gents had loads of soft faults so tested voltage and it was showing 13.7 at battery on tick over 2000 revs same under load drops to 12 so deduced that alternator gone it was the original and I have done 145k so not a bad deduction - so changed it but I am still getting the same results anyone have any ideas what it could be ?
Post #446631 4th Aug 2017 4:00pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Could be a number of things, do the obvious and check battery leads are ok. i would check all electrical connections are good (unplug/reconnect), check all screw connections are tight, clean with electrical contact cleaner all spade connectors. Have a look at relays where possible, perhaps a winding is breaking down.
If you have a portable radio turn it on and place it near the running engine, if there are any shorts it will create a lot of interference (any arcing transmits a wide band radio signal and also can cause a lot of current resistance).
If your really unlucky it could be the replacement alternator. In the "good old days" you could do your own referb' :- diode pack, new brushes and nose bearing.
Sorry cant be of more help, i guess you will have to break out the multi-meter and start doing point to point checks for continuity.
Post #446655 4th Aug 2017 7:43pm
Sandyt
Yes think so it was so much easier in the old days as you say doing own refurb was really satisfying
Post #446656 4th Aug 2017 7:46pm
If you have a set of jump leads try using one to connect the engine block to the battery -ve terminal and see if it improves things. Any lump of metal or bolt head on the engine block will do. Thumbs Up
Post #446658 4th Aug 2017 7:57pm
Sandyt
Will do I had something similar with my old p38 the lead from the alt to the battery was corroded internally
This all started when I had all the tensioners and pulleys replaced all belts were under good tension very odd
Post #446660 4th Aug 2017 8:06pm
