![]() | Home > Technical (L322) > Brake Caliper Question |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
I've just replaced the rear brake caliper on my car...
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
How do you think they got them on in the first place |
Thanks for the advice, just thought I would check! |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
nothing to worry about mate.. alot of the time the slider pins are the culprit which when seized cause more damage heating everything up causing the rubber seals to deteriorate. Always use a silicone based grease for the pins. Seen some folk using copper grease which is blasphemy as the rubber boots swell ans give up. Current:
