Home > My Range Rover > New memeber we just picked up my vogue se
Page 1 of 3 123>
Rob199027
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Hi there
Just sold my rrs and came over to the vogue side and wow what a difference just picked up my 2010 vogue se tdv8 !
In black 88k full Land Rover history fully loaded with rear entertainment paid £14850 for it ! Was that a good deal ?
Cheers
Rob Thumbs Up [/list]
Post #446750 6th Aug 2017 6:33am
Rob199027
Also need to top my coolant up but don't know what colour is used says pink or orange ? It has always been serviced at land rover which colour do they use ?
Post #446751 6th Aug 2017 6:36am
GGDR
Pics please!
Well done! Cheers, Greg
Post #446752 6th Aug 2017 6:47am
Rob199027
Going to clean up today post some pics later on
Post #446753 6th Aug 2017 6:54am
Rob99
Welcome to the club. Sounds like you had it at a good price too Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #446760 6th Aug 2017 8:31am
Any OAT based coolant. You can buy it from Halfords ready mixed for a few quid, it's the one which is t green/blue. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #446762 6th Aug 2017 8:38am
Rob199027
Cheers also does anyone know how to get oil level up on dash I have to start car to
Get clocks up press ok and the service bit I can scroll on to ? Cheers
Post #446772 6th Aug 2017 9:31am
Rob99
I think you can only check oil level with ignition on but not running. Then it should come up in the menu system. 2021 D350 Fifty Edition - Carpathian Grey
Post #446773 6th Aug 2017 9:34am
as Rob says, ignition on will reveal the oil level menu..has to be done when the oil is warm i believe, its all in the owners manual.. ... - .- -.
Post #446774 6th Aug 2017 9:36am
Baltic Blue
Sounds a very good price for a 2010 model.
Is it a 3.6 or 4.4 tdV8 ? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #446779 6th Aug 2017 10:00am
you should check the engine oil when warm, go for a drive, let the car stand for 10 mins then press the ignition button without your foot on the brake.
turns the screen on.
then press the steering wheel button to get the menu up and navigate through the service menu to the oil level check.
If it says oil level not available then open the bonnet. It will read the level if the bonnet is open even if the car isn't quite ready to display it...... There is nothing that can't be fixed with a hammer😜😜
Post #446781 6th Aug 2017 10:16am
Rob199027
Cheers guys also is a 3.6 tdv8
Just checking coolant level (I'm abit clueless when it comes to antifreeze etc I have bought the pink one
I have check the level and took a picture as unsure wether it's really low as I undone the little screw next to main filler cap and loads off coolant rushed down in to main tank and put the coolant level to between the guide lines any help be great and the antifreeze in the car is orange and one I have is pink can I mix or does it have to be orange ?
Post #446786 6th Aug 2017 10:54am
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Welcome to the forum and its deffo a steal mate, very good price.
I prefer not to mix it. I was in the same situation and therefore did a full drain.. gives you peace of mind. Although if its the same kind then mixing shouldnt be a problem. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #446788 6th Aug 2017 11:04am
Rob199027
Hi there
Tbh I only want to top up abit so I can feel safe I'm getting booked in at my local indie for a drain and service so you think he ok just to top up with the pink ? Just till next week
Post #446791 6th Aug 2017 11:11am
scotcruz
If its just next week.. top up it up with water.. its wont cause any harm.
Its is something you can do yourself too.. Fairly easy job Current:
Past:
Post #446792 6th Aug 2017 11:16am
Page 1 of 3 123>
