![]() | Home > Technical (L322) > Tdv8 cooling system |
| Sharpy1980 Member Since: 20 Nov 2016 Location: Kent Posts: 55
Does anyone have any info on the above like a schematic or picture of the back of the engine as I have a leak coming from the back of the engine that's running down both sides of the gearbox bell housing I can see up to back of the heads and can't see any signs of it so I'm assuming it's something lower down in the valley, I can't see anything at all from the top but then even if it was leaking at the front of the valley and running back I doubt I'd see it lol, it's loosing about a litre per 2 weeks so not much, I will admit this is for my rrs but you guys seem to be more hands on, that said I will probably have to take the body off to fix it |
Yes that's perfect, it must be from somewhere in those connections right at the back, I was a little worried what it might be but after seeing that it could be as simple as loose pipe clip especially as they are probably the squeeze together ones, now I've just got to figure the best way to get in there, I have been toying with the idea of lifting the body to do a few other jobs but I don't like having a water leak so I suppose it's either the inlet manifold or the gearbox out. |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786
Get one of those cheap inspection cameras so you can get in and have a closer lookz There is nothing that can't be fixed with a hammer😜😜
Yeah it's actually a really good one but I still couldn't find it (not that good then), I got myself a coolant pressure testing kit since so it might be worth me trying again with it under pressure |
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119
Unless it's a sport you can't left the body.
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1558
yup - 2 bolts and the pollen filter comes out giving loads more space around the rear area.
Sadly it is my sport, our fattie is a Td6 so even more room |
