Home > Technical (L322) > Abs issue
alistairh
Abs issue
Ok hoping somebody can help . Done a bit digging and ran the iid tool so hopefully shed some light. Every time cars started and I set off the brake pedal moves about an inch then resets. After that alls well..started getting a select neutral and range icon flashing, also occasionally getting a permenant brake switch fault which hasn't shifted after replacing sensor..when brake switch fault pops up so does the xmas tree lights...anyway battery's brand new and charging systems well so ran the iid tool doing live data and got some strange readings....
For some reason I can't read wheel speed? If I select the transfer box live data which shows it, it's there and as it should be.. it's only the abs that's blank..anybody had a dodgy module doing similar?
Post #447020 7th Aug 2017 11:25pm
I've also got an abs problem:
Big Cry Rolling with laughter .
Post #447022 8th Aug 2017 12:52am
alistairh
Laughing very good lol
Post #447024 8th Aug 2017 6:58am
alistairh
Got some great help from the guys at gap diagnostics regarding wheel speed sensor non show and my faults. Best piece of kit you can buy and the aftercare is amazing..
Post #447152 8th Aug 2017 10:13pm
